80 sc sunroof issues
I have an 80 sc with a sunroof. Lately, the roof opens fine but when I go to close it, about 60% of the travel, it slows down. Almost as if it is getting hung up. The motor that opens the roof works fine when it is disconnected from the gear box. I have tried to find access to the cables that force the roof to open or close to no avail. What is the best way to access the entire system to see what I need to do to get everything up and running. Thanks.
Old 07-24-2017, 12:23 PM
Administrator
Luccia at Pelican Parts's Avatar
Maybe take a peek at our sunroof tech articles and see if they might help you to access components of the sunroof. I'm sure other Pelicans will chime in with input as well. Good luck.
Porsche 911 Sunroof Repair | Pelican Parts DIY Maintenance Article
Porsche 911 Sunroof Repair 101 Projects | Pelican Parts DIY Maintenance Article
Old 07-24-2017, 12:54 PM
You have to remove the roof then take out the tracks and cables and clean everything with a solvent like brake clean. Don't be intimidated it's not that hard to do. Search (removing and replacing sunroof cables) there's
plenty of photos to help. Also YouTube is your friend when it comes to this kind of repair.
Old 07-25-2017, 06:18 AM
https://www.youtube.com/watch?v=EOejYGMcc7c
Old 07-25-2017, 08:15 AM
As stated, remove the cables and guides, clean with solvent and reinstall DRY. Don't
ever use any lube or grease as it attracts dirt and debris and causes the kind of problems you are experiencing now.
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 07-25-2017, 08:27 AM
