Tony
Maxhouse97's Avatar
ER front bushing install - where to buy pipe wrench?
Anyone have a recommendation of where to buy the long pipe wrench he uses in the video? I'd rather not use the threaded insert and washer/nut system that others have used since I don't want to remove the t-bar sealing plate on the front of the a-arm.
https://youtu.be/85-Enx4bKUE
Tony
22 GT4
04 E46 M3
87 Carrera (sold - craving aircooled again)
12 991 Carrera (sold)
Old 07-26-2017, 07:01 PM
gtc gtc is offline
abides.
gtc's Avatar
I got mine started on the a-arms, then whacked them home with a deadblow hammer.
Not the recommended method, but it was quick and easy.
Graham
1984 Carrera Targa
Old 07-26-2017, 07:06 PM
I just did this last week! I hit my neighborhood forum and borrowed one. Worked like a dream.
1982 911 Targa, 3.0L ROW with Webers
Old 07-26-2017, 07:39 PM
Under the radar
Trackrash's Avatar
Not a pipe wrench. It is a wood worker's bar clamp. There are cheap versions using a pipe. Maybe that is the confusion.
https://www.google.com/search?q=bar+clamps+home+depot&ie=utf-8&oe=utf-8
Home depot has them https://www.zoro.com/bessey-pipe-clamp-cast-iron-34-in-bar-size-pc34-2/i/G4171959/feature-product/b?gclid=EAIaIQobChMI5LrbiMSo1QIVjIp-Ch2JNw8VEAQYBCABEgJf-PD_BwE&gclsrc=aw.ds
Gordon
'71 911 Coupe 3,0L outlawed
Old 07-26-2017, 08:28 PM
Puma's Avatar
Woodcraft.com for the ends
Hardware store for the pipe.
2001 986 S
Old 07-26-2017, 10:15 PM
Get threaded rod and use of to knock the end plug out, they come out easy and go back in Easy too, that way with some spaces and sockets it pulls straight in, and it's just a cheap threaded rod. I tried the clamp since I own many and it was a PITA, so I used the threaded rod and it was easy
Ächtung Kraft Founder - Custom Porsche Parts and Leather
http://achtungkraft.com - Bryan Rasch - bryan@achtungkraft.com
INSTAGRAM // @AchtungKraft // @BrightonRennsport
1972 911 ROW Steel Wide body Outlaw w/'86 turbo drivetrain
1976 911S + 2006 911 4S + 2009 Cayenne GTS + 1988 944
Old 07-27-2017, 05:26 AM
Bollweevil
Originally Posted by brasch View Post
Get threaded rod and use of to knock the end plug out, they come out easy and go back in Easy too, that way with some spaces and sockets it pulls straight in, and it's just a cheap threaded rod........ so I used the threaded rod and it was easy
^^^^^^^^^^^ This is the cheapest, easiest way IMO..
Jack
74 911 Coupe
2.7L - K21 Option - S suspension
Old 07-27-2017, 06:58 AM
Tony
Maxhouse97's Avatar
Thanks - yes I already had the a-arm powder coating and am worried about breaking the integrity of the coating if I knock out the cover.
Tony
22 GT4
04 E46 M3
Old 07-27-2017, 05:06 PM
Tony
Maxhouse97's Avatar
Bar clamp does clarify things...
Tony
22 GT4
04 E46 M3
Old 07-27-2017, 05:07 PM
TheSt|G's Avatar
Powder coating is good and all, but be aware it will be a tighter clearance now to get your bushings on. Also, get the specialty socket for the castle nut, and then put a jack on the back of your torque wrench when loosening/tightening it down. Makes the job cake.
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs
2005 E46 M3- Daily Beater - 3350lbs
Old 07-29-2017, 04:18 AM
Tony
Maxhouse97's Avatar
This is what I ended up getting. Cheap and effective, another tool I can keep for other projects. Just need to buy the pipe.
Bessey BPC-H34 3/4-Inch H Style Pipe Clamp https://www.amazon.com/dp/B0012YNJRO/ref=cm_sw_r_cp_apip_1RdXVEaQJkiaF
Tony
22 GT4
04 E46 M3
Old 08-30-2017, 06:41 PM
