For all you suffering from a mouse nest in the A/C
I have a friend that owns a independent garage he turned me on to a product that eliminates all the bacteria left behind after a mouse nest has been cleaned out but still leaves behind a nasty film and smell. With this product you don't need to R&R the a/c assembly to clean it out. You have to vacuum out all the nest you can using a blow gun and a shopvac. Then you drill a small hole in the evap housing to install a supplied nipple and inject this foam product into the housing it then expands to all the nooks and melts away leaving the area clean plus destroys all the smell and bacteria. Very cool.
Old 11-03-2017, 02:37 PM
Administrator
Dmitry at Pelican Parts's Avatar
What is the product?
Old 11-03-2017, 03:38 PM
kuehl's Avatar
Good food for thought,
Here are some ideas:
General overall southern approach
Adventure Fink's approach
If you got chickens getting in your car
911 Evaporators
Kuehl
1987 911 cab, modified
https://griffiths.com/
Old 11-05-2017, 06:37 AM
This is the product
Old 11-05-2017, 07:29 AM
