orange/brown wire with white line, what is it for
1980 911 SC Targa, took out the carpet and wood panel to gain access to the clutch cable. I found the wire in the photo just laying there by the accelerator linkage. Any idea where this goes? Thanks in advance.
Old 08-07-2017, 06:45 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Other SC owners will chime in but that is just a ground wire for maybe a auxiliary component like rear fog light??? I would tape it off as not to have an errand short.
'85 Carrera Targa
PCA/POC
Old 08-07-2017, 06:52 PM
schoward's Avatar
From memory, nearly certain my U.S. 81 has the same wire in there dangling as well. My clutch switch for the cruise is hooked up so that is not it. Everything works on my car so guessing it's for a feature or option not in my car.
Scott
1981 911SC Targa - Platinum Metallic
Old 08-07-2017, 06:58 PM
ROW '78 911 Targa
timmy2's Avatar
Spare wire in all through body harnesses. Maybe for sportomatic switch at shifter as it does go to the male 14 pin connector. It is brown/white which generally is a switched leg.
Haven't done any sportomatic harnesses other than an engine harness. Can't remember if the 14 pin female used that position. Just leave it there. Can't do any harm.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 08-07-2017, 09:19 PM
theiceman's Avatar
maybe its a leftover, didn't there used to be a stop light switch on the pedal cluster at one time ?
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 08-08-2017, 08:52 AM
thank you everyone. You all are correct because there is no where to plug it into and very short so it's not possible to donnect it to anything nearby.
Old 08-08-2017, 12:39 PM
