Help Identifying Part
I'm reaching out for help identifying this part number. I noticed that the part was hanging down and I was able to pop it back onto the ball joint but the rubber insert looks like it could be replaced.
The droplink for the swaybar pops onto the trailing arm pivot point. There is a nylon bushing inside the drop retainer.
When you replace the drop link buy it with the nylon bushings installed on each end as you'll not get them together at home. Bruce |
Runnin on empty
Articulated bushing. Your stabilizer bar is disconnected. You should inspect all your bushings.
'74 911, Steel Wide Body Hotrod, 3.0, Jenvey ITB’s, AEM Infinity, KW V3's, Eibach Sways, JWest shifter and other stuff. https://forums.pelicanparts.com/porsche-911-technical-forum/1006126-midi-modded-bumpers-led-headlight-manifold.html |
I'll most likely just get a new bushing by itself and go crazy trying to work it in. |
901 343 782 00 for the round bushing.
I'd call a recycler but your style ceased to be used after 77, so it's all old.
Bruce |
