fastfredracing's Avatar
Perfect leakdown numbers but 30 lbs difference in compression from bank to bank ?
I checked this car out a few years ago, and got the same results . The customer believed that I may have run the test wrong, but I have done it the same way my whole life .
Engine hot, fuel pump/ignition disconnected, throttle blades blocked wide open, and a battery charger connected so it spins same speed . . I checked the cylinders in the order of the firing order .
This is on a 2.0 e motor . I got less than 4 % leakdown numbers on all cylinders . Only one was 4, the rest were 3 or less.
The left bank ( 1, 2, 3) show compression numbers between 157-160. The right bank show numbers in the 128-130 range . Car runs flawlessly, no smoke, or strange noises, no blow by in the tank, and it will sit and idle at 500 rpm all day, smooth as can be , if you want it to .
I am guessing that cam timing is skewed between banks, or that maybe it suffered a timing chain failure at one point in its life, and maybe had heads/barrels, cams got replaced with mis matched parts ??
Any other ideas ?
No left turn un stoned
Old 08-07-2017, 03:08 PM
Cam timing is my guess.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 08-07-2017, 04:28 PM
You're probably right. Hang that dial gauge on it. Had a 964 recently that was 1 whole mm different.
206 637 4071
Old 08-07-2017, 06:11 PM
No timing chains in that 4 cylinder. Would be hard to change timing bank to bank. When the dots line its is in time.
Thinking outside the box here but maybe an exhaust or intake restriction.
Perhaps the valve lift is shorter on that side? Bent push rods? Flat lobes?
Interesting question!
2008 BOXSTER S LE
2008 CAYENNE GTS
Old 08-07-2017, 06:21 PM
We're talking 911. No push rods in that 6 cylinder.
Dave
1969 911T Coupe
1972 911E Targa
Old 08-07-2017, 06:25 PM
Old 08-08-2017, 06:31 AM
Wrong forum, perhaps?
Old 08-08-2017, 07:19 AM
Any other ideas ?
I see this a lot with Ferrari V8 where cam timing is very sensitive...
3 dergrees at the crank will cause compression to drop on one bank vs the other. You look at the results and all cylinders on the same side is uniformly lower and you just have to conclude that cam timing is out on one side.
Old 08-08-2017, 07:20 AM
Or wrong planet!
Old 08-08-2017, 09:25 AM
I misunderstood. When the OP mentioned 2.0 E motor I thought 912E (type 4 VW)
2008 BOXSTER S LE
2008 CAYENNE GTS
Old 08-20-2017, 07:30 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Static differential is a great tool for diagnosis.
http://www.aviationpros.com/article/10388599/cylinder-differential-compression-testing-subject-to-interpretation
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 08-21-2017, 05:41 PM
T77911S's Avatar
right side cam may be retarded(in relation to left).. gives it less time to build compression. that's a lot though, I would be curious how much cam timing that would have to be if that was it.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 08-22-2017, 04:23 AM
