Location: Rehoboth Beach, DE summer - Indian Wells, CA winter
Cloudy windshield
My 1988 930S, 60,000 miles, has developed a cloudy white area in the bottom left hand corner of the front windshield. I don't see any obvious reason or any hint of a water leak that might be causing the discoloration. The weatherstripping is original but looks in great shape and is quite pliable where it abuts the body. The car is not driven in the rain and stays in the garage except for an occasional weekend drive. The rest of the windshield is totally clear.
I have tried wiping the area, both inside and out, with Windex but that had no effect. It is almost as if the discoloration is in between two layers of glass. (Not sure if this windshield is solid or made of various layers.)
Any thoughts? Thanks.
Old 08-07-2017, 02:55 PM
Possibly could be delamination.
Old 08-07-2017, 03:00 PM
Slippery Slope Expert
Steam Driver's Avatar
That is a deterioration of the plastic laminate layer between the two layers of glass. It is just a sign of aging. Nothing can be done to repair it except a new windshield. And I don't think anything could have done to prevent it. It doesn't really seem related to inside/outside storage conditions or much of anything else. Just aging.
It used to onset sooner than it does these days which I'm sure is because of changes in plastics chemistry. So some age quicker than others (just like Us!). My SC little to none of the issue yet, while my Honda CRX displays quite a bit of it. As long as it doesn't progress into the major viewing area it's a cosmetic issue only.
Old 08-07-2017, 03:05 PM
both sides on the bottom are the same way in my 77 911S and when it bothers me too much I will have the windshield replaced.
Old 08-07-2017, 04:33 PM
wayne robson's Avatar
Cloudy windshield
930slant---A possible reason is ,when you wash your 911 is there a slight lean to that side after you wash it,reason water will sit in that side windshield seal,even if you dry your car off moisture can sit inside the seal and cause this.
Brings up another matter how many times do we wash our cars, i believe far to many times, i do mine once a year,but use a damp chamois to dry every time i finish driving my car, then cover it until used next.
And depends on how and where we drive them.
Old 08-07-2017, 07:47 PM
El Duderino
tirwin's Avatar
Delamination. Mine did the same thing. Pulled the window out to find rust in the corners of the seam. Ground it down to clean metal and treated it with POR-15.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 08-07-2017, 09:11 PM
Peter Zimmermann's Avatar
Yep, this is a water-entering problem. I found it to be more common on cars that are frequently hand washed and put away damp/wet, or, simply, cars that get left outdoors in bad weather. Replacement required to fix. Always replace the rubber seal when replacing the windshield, the seal is probably most of your problem; it has allowed moisture to enter.
Keep the Shiny Side UP!
Pete Z.
Old 08-08-2017, 07:41 AM
Hey, Thanks for all of the replies. Delamination is my hope rather than a leaking seal and rust. All of my seals appear to be in good shape and I always dry my car immediately after washing it. In any case, I'll live with it until its gets much worse.
I've heard so many stories about problems associated with leaking gaskets after replacing a windshield. That is one reason I've avoided replacing my rear windshield even though the plastic insert has worked its way loose in some places over the years. Thanks again.
Old 08-11-2017, 02:08 PM
My windshield delaminates in the same area on my 77 Targa. Insurance company paid for a new saint goblin w.s.I provided an OEM Porsche gasket, installer did a great job. Most insurance companies have glass coverage with no deductible. I have State Farm, no problem...
Old 08-11-2017, 03:31 PM
911 Mania
I got this replacement windshield contact off previous Pelican post and am accumulating info and contacts for my eventual project.
o Prosource Glass International.
o PO Box 996
o Andover, MA 01810 (877) 345-2800
o Email Richard @ richardt@prosourceglassintl.com and tell him got info from Pelican Parts forum. Sekurit windshields.
As mentioned by others, buy Porsche only window rubbers to ensure best and proper fit.
"When the debate is lost, slander becomes the tool of the losers." Socrates
Old 08-11-2017, 05:43 PM
