Parts needed to install Carrera brakes in 911SC?
Hello all,
I've searched forums and researched enough to eliminate Boxster brake kits and other aftermarket solutions; but with a 3.2 going in my '82 911SC I'd like to optimize my braking by at least installing the wider Carrera front discs to offer a bit more fade resistance. However, I can't find a list of what parts I need to do so (besides the discs of course). Different calipers? Master cylinder/booster? Etc.?
Any advice would be much appreciated!
Jonathan 1982 911 SC
Old 08-09-2017, 09:59 AM
Originally Posted by JHanson View Post
Hello all,
You just need the larger calipers, and 24mm discs.
No need for larger MC or booster.
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 08-09-2017, 10:25 AM
gtc gtc is offline
abides.
gtc's Avatar
FYI, the rear 3.2 calipers have larger diameter pistons, which will change your brake bias.
Graham
1984 Carrera Targa
Old 08-09-2017, 10:42 AM
Hi J,
I went with the Carrera fronts on my SC.....added the spacers to the stock SC front calipers to widen them for the Carrera rotor. Stock SC on rear. PMB did the caliper work (rebuild. re-plating, etc). Slight improvement for the 3.6 power.
pd
Old 08-09-2017, 12:29 PM
Thanks very much—exactly the information I needed. I'd already decided to leave the rear brakes as is because of the bias issue.
Old 08-09-2017, 01:32 PM
jamesjedi's Avatar
Do a search for information from Bill Verberg.
I have similar brakes. Carrera front brakes, SC rear brakes (both calipers and rotors). I believe the Carrera had a bias valve installed that created a brake bias that would favor the fronts more. I am not certain, but I don't think you have this valve on your SC. The end result of not having the valve is that the balance is not unfavorable when using Carrera front calipers and rotors with SC calipers and rotors.
Perhaps Bill V will elaborate. He is usually very good with his contributions.
Old 08-09-2017, 02:32 PM
Thanks James. About half the useful information I found while searching was from Bill.
I was curious about the bias with Carrera fronts and SC rears, but it seemed there wouldn't be an issue.
I notice Pelican has drilled aftermarket rotors for quite a bit less than non-drilled factory rotors. Does anyone have an opinion on that? Or advice on pads and fluid?
Thanks again . . .
Old 08-09-2017, 03:48 PM
jamesjedi's Avatar
Hopefully Bill will chime in. Or, you can do the math with the charts on this site. I would like to know the exact numbers as well.
Old 08-09-2017, 03:56 PM
Jeffreypang911's Avatar
I just installed 87 front calipers and kept my 74 rears. Running without booster. Feels great. I was worried about the bias but it honestly feels perfect.
Old 08-09-2017, 09:34 PM
IROC's Avatar
To simply answer your question, all you really need in the front are Carrera calipers and rotors. IIRC, the brake lines mate right up. If you choose to put Carrera calipers in the rear, in addition to the calipers and rotors you'll need new hard lines to the calipers (or at least I did).
I've been running Carrera calipers since about 1995 with no bias valve and have had zero issues.
Edit: Love the overland expo stuff. I have an 80 series and 100 series Land Cruisers and love that stuff...
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 08-10-2017, 03:05 AM
Bill Verburg's Avatar
Thanks again . . .
Here's a comparison of the various 911 brake setups, Ideal is right around where the original 911 S/M or A/M setup is. Using Carrera 3.2 on the front only has zero effect on bias, ie Carrera 3.2 wide front w/ pre'84 rear M is the same as pre '84 A or S / M. The only deficiency that stock brakes exhibit is thermal capacity in track use on heavier and/or more powerful 911s. Thermal capacity in front is the weakest point, so going from the 20mm to 24mm rotors is a small improvement, adding cooling in front would be another improvement, using ceramic/metallic track pads all around and high temp fluid are other steps that can be taken. 3.2 Carrera wide rears induce too much rear bias, a rear p/v is a bandaid that helps the bias issue but is no substitute for proper native bias. the reason a p/v is a bandaid and not a solution is the binary nature of the resulting bias, ~1.22 below 33bar and 2.26 above results in too much rear below and too much front above.
The key # to look at here is the last column brake torque bias
Bill Verburg
Old 08-10-2017, 04:31 AM
Thanks very much, Bill. That's perfect information for me.
Old 08-10-2017, 07:35 AM
