theiceman's Avatar
any tips for driving out pin on clutch helper arm ?
pretty straight forward question
For those of you following my clutch cable saga I had a missing seal above the clutch helper arm go " missing" , water got down and seized the arm on the cross shaft.
got it un-seized, I just need to get the arm off so I can put the seal on and some grease on the shaft . that pin is tight , cant seem to get it to budge. using a steel punch and 5 pound sledge but admittedly cant get much swing action under the car on jack stands, was going over to my buddies lift but just thought id try it first .
Not sure if getting a torch up there is such a good idea but maybe for a few seconds it would be okay ?
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 07-25-2017, 01:01 PM
I hate to be the bearer of bad news, but I spend probably a day, maybe 2 trying to hammer that pin out while laying under my car. The issue I ran into is that you'd work the pin so far out, then due to the curve of the gearbox for the diff, your punch would be at an awkward angle which would result in your punch just hitting the walls of the hole in the shaft. So I just progressively used shorter and shorter punches until I ran around the house looking for hardened nails to be used as punches.
Old 07-25-2017, 01:07 PM
proporsche's Avatar
Hi..no problem using the hammer but you need the space to do it right.Wait until you get to your friends shop.Also use the heat it will help, just don`t melt it together...;-)
Ivan
Old 07-25-2017, 01:10 PM
theiceman's Avatar
Thanks Ivan that's what I was thinking. yes Will I pictured that too .. or get 3/4 of the way out and the pin hit the exhaust ... NOW your screwed lol
Old 07-25-2017, 01:26 PM
proporsche's Avatar
I f i remember ..yes you will hit the crossover pipe but do not worry, once you get it going it will go.But remember in your case you can already move the arm so the angle is changeable..
Ivan
Old 07-25-2017, 01:29 PM
Air hammer and a pointed bit to get it moving. Punch and hammer to finish. Face shield.
206 637 4071
Old 07-25-2017, 01:46 PM
theiceman's Avatar
Thanks John .. I think I need to make my pointed bit more pointed as it jumps around all over the place.
Old 07-26-2017, 08:28 AM
Peter Zimmermann's Avatar
Ice; as you've discovered, that pin is a bi**h! Get the car up on a hoist, use a bit of heat, and give yourself some room to use the hammer. Wear eye protection! I found a flat-ended pin punch, about 4mm, maybe 5mm (it's been a heckuva long time since I did that job) worked best for me (hold the punch with a vise-grip). Use a hammer that is a different material than your punch (steel punch - brass hammer); that will reduce the amount of bounce back.
Keep the Shiny Side UP!
Pete Z.
Old 07-26-2017, 08:58 AM
theiceman's Avatar
lol so true Pete .. after an hour or so last night I gave up with it on my jack Stands.
I got myself a nice set of SSIs and a Dansk muffler and old oil style lines. I think I will go to my buddies , take the old exhaust off and that will be the time to get that pin out. While its up on his hoist.
definitely a challenging Job
Old 07-26-2017, 10:15 AM
proporsche's Avatar
I have fait in you ..you can make it;-)
Ivan
Old 07-26-2017, 10:21 AM
franklinstower's Avatar
exactly. 5 minute job with pointy air hammer bit.
Old 07-26-2017, 10:23 AM
Then leave the pin out.
206 637 4071
Old 07-26-2017, 10:39 AM
theiceman's Avatar
are you kidding ? if I get it out its getting its own frame and going on my wall of fame !!
Old 07-26-2017, 10:40 AM
proporsche's Avatar
yup iceman ..as i said in the other post
Originally Posted by proporsche View Post
Just one thing..do not put the pin back, it has no use..Just lubricate the shaft with a lot of Bosch grease or Sachs grease nowadays...also do not forget to get those seals for up on the arm and between the arm and the little finger
Ivan
Old 07-26-2017, 11:03 AM
theiceman's Avatar
Ivan
yeah Ivan I did see , sorry for the misunderstanding , I meant not only was I not putting it back in , I was framing the thing !!
Old 07-26-2017, 11:31 AM
proporsche's Avatar
I just realized you are the guy with the hockey stick in the engine right??
Ivan
Old 07-26-2017, 11:48 AM
theiceman's Avatar
lol yup
Old 07-26-2017, 11:52 AM
proporsche's Avatar
funny hockey is part of my live since 8 year old;-)
Old 07-26-2017, 11:57 AM
theiceman's Avatar
well.. unless you think that guy is an a-hole ... then no !!
but that avatar has followed me forever
proporsche's Avatar
did not quite understand about the a hole??;-)You play hockey or not?
Old 07-26-2017, 12:00 PM
