Easy there tiger, don't take my word for it - read Steve@Rennsports comments on turning rotors: https://rennlist.com/forums/911-forum/977018-turn-rotors-on-911-a.html http://forums.pelicanparts.com/porsche-911-technical-forum/397161-brake-disc-question.html http://forums.pelicanparts.com/porsche-911-technical-forum/491316-930-brake-rotors-thickness.html I'm certainly not advocating wasting money - my point is that there are things you don't skimp on -brakes and steering being at the top of my list, and that there are other marques that are more economical to maintain. |
Not sure what he's talking about. Stock thickness is 24 mm. Minimum is 22mm. I'm still above minimum even with the turning that was done. There's a reason they list a minimum thickness. Having brake rotors turned isn't really "skimping" IMO. I have had the rotors turned of almost every vehicle I have owned including an F350 that was used almost strictly for pulling a 3900lb trailer with machines weighing over 8000lbs. I have never suffered a failure due to turned rotors. I have OTOH suffered problems related to stuck caliper pistons and a brake line rupture. So if I were to call something "skimping" I'd have to say it's rebuilding calipers or driving around on old brake lines. |
He means 322 mm in diameter, not thickness. And calipers are meant to be rebuilt, hence the availability of replacement pistons and seals. Rotors are a known disposable part.
Don't get me wrong here. I'm simply going to end the myth here that rotors are supposed to be tossed. It's a silly notion that is based on no real fact. If all four brakes are working properly, there's no reason you shouldn't turn rotors unless their is noticeable bluing of the rotor meaning they have gotten WAY too hot. Then, yes, you get rid of them because they have lost some of the tempering. Otherwise, turning a rotor does not make them any less safe or places like Oreilly's wouldn't do it nor would the shop that did mine. |
On second thought though, I know most of the judges so... no, not really. The worst part is, I was a judge one year and STILL lost. :eek: |
Cab,
When I first read the thread, I was solidly in the "just buy new ones camp." Now, you won me over, I think since rotors have become so cheap, most of us just replace, or we've run them so long that they couldn't be turned safe. On the other hand is my DD Toyota which are probably cheaper to buy new than get turned and since I park it outside, they usually have a "nice" rust crust on the outer edge. One less thing in the landfill, well they do get recycled, but that takes energy too. Best, Rutager |
Yours aren't too thin, however. They just aren't working the way you want them to. Finally, back when Porsche made the rotors for your car, they were the only ones making them. If you wanted a replacement, they were probably $500 each from the dealer. Now, there are aftermarket rotors that cost next to nothing. What year is your car? Pelican has rotors for a 1983 for example, that are TWENTY TWO DOLLARS. That's right, 22 bucks for a rotor. Pelican Parts - European Automotive Parts and Accessories - Porsche • BMW • Mercedes • Volkswagen • Audi • Saab • Volvo • MINI Why would you ever fcuk around with turning them when they can be had for 22 bucks? Just the bandwidth you wasted on this thread is worth 22 bucks alone. |
Please... don't hesitate to move along now and stop wasting your time. |
One more side thread for brake geeks
I asked if people thought the direction of rotor air scoops (in the middle of the rotor) mattered about a week ago on Cayenne forum (Early Cayenne Turbo's are HEAVY cars, big brakes) and I got a ton of opinions and learned more than I though I would. https://rennlist.com/forums/porsche-cayenne-forum/1005857-rotors-does-l-r-side-really-matter.html |
| All times are GMT -8. The time now is 11:01 AM. |
