Ride Quality---shock comparison
My car: 1983 911 coupe, lowered to Euro, no bump steer spacers, recently aligned, new Boge shocks on rear this spring, presumed original Boge fronts. Michelin Pilot Sport AS3 new this spring. Fuchs 6 & 7. 122k miles.
My brother's car: 1979 911 coupe, stock US ride height, recently aligned, presumed orginal Bilsteins front and rear, Michelin Pilot Sport AS3 new this spring. Fuchs 6 & 7. 95k miles. So when driving around rough city streets or highways with pronounced expansion joints, my car exhibits more of a sharp "bang-bang" and I can feel it in the seat. It gets pretty annoying. On faster back roads when I hit a bumpy corner at speed, it feels a bit like the car is wanting to skitter a little instead of staying grounded. Hard to be certain, but the car's ride didn't really improve after fitting the new rear shocks this spring. When I drive my brother's car on the same streets, it takes the sharp bumps much better. There's much less sharp feel through the car's chassis and seats, and more of a "thoomp-thoomp" sound that a more newish car might exhibit. Yet, his car handles really well, it's not like its soft or mushy, it just feels like the shocks are doing their job better. It feels more sorted. It does have a bit more body roll being at stock US height, but that's the only knock against the car's handling. I've read a bit here about Boge vs. Bilsteins, but didn't find an answer that would explain this situation. If someone has experience with both brands, does my explanation sound like a good comparison between the two brands? Could worn suspension bushings in my car also cause more of the "bang bang" over bad surfaces? I'm planning to drop my front suspension and rebuild this winter, and want to pick the best setup for this car. Even if that means swapping out my new rear Boge shocks for Bilsteins.
1983 SC Coupe Chiffon White 3.0 rebuilt by me 9.5:1 964 Cams. SSI's. Backdated heat. KEP sports clutch. |
Under the radar
Are your Boge shocks high pressure shocks like the Bilsteins? If not that could make a difference as well. How do your sway bars compare?
If your suspension rubber is original, it is probably time to replace. I did this to my 88 a couple years ago and it definitely improved the sharpness and the ride.
Basically, if it was rubber and part of the suspension, I replaced it. Almost all of it was stock or near stock performance. I didn't go monoball, and kept it all rubber as this is not a track car and I didn't want too harsh a ride. Sway bar bushings, spring plate bushings, front and rear control arm bushings (went with elephant racing on these), strut mounts, ball joints, tie rod ends were all replaced. It was all original and much of it was obviously not in great shape. I also had my Bilsteins rebuilt by Bilstein. This also removed a slight shimmy at 80+, so something was definitely worn. I lowered my car to probably a hair below Euro height and the bump steer kit definitely helped. You want the tie rods to be on the same plane as they were when it was at stock height. It does make a difference in the feel of the way it handles when it hits those bumps. Obviously a good alignment and maybe a corner balance after that is required.
1988 930 Venetian Blue |
and "asuming" that not recently changed parts are still good, is not really a good basis to start with. looking at the 911's drive chassi you have: - bushings - shocks - torsion bars - sway bars further: worn engine/tranny mounts can effect handling too if the engine swabbles aroung when cornering unless you are not absolutely sure about ALL of these part beeing in good order it may be the day to adress them when you are not happy about your cars handling and since there are "hidden" parts you cannot check from the outside, such as the torsion bars or the front shocks in the tube..., well, you must decide to retreive them to check. and even if the bushings look ok (not torn/ripped) they get worn, get hard and crunch making any alignment actally a bit obsolete. so don't "asume", but rather "make sure".
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit Last edited by Flojo; 08-31-2017 at 02:35 AM.. |
Any photos of this US height and Euro height? I'm guessing your car is much lower than factory euro height.
Matt - 84 Carrera |
El Duderino
Lowering a 911 without any other adjustments reduces the suspension travel distance. It could be that what you're feeling is the suspension maxing out. I have a friend that has this problem on his '83 right now. We went for a ride the other day and you can feel and hear it. He is in need of a suspension refresh and we're talking through options and budget now.
As Bill mentioned, a custom digressive valve job does wonders. How much resistance the strut provides is a function of strut compression speed and force. With a normal strut the response curve is linear. With a digressive valve the response is non-linear. The goal is to get comfort when you want it and stiffness when you need it. Low force and compression velocity and the suspension is relatively soft. High force and compression velocity and it gets really stiff. It can be a beautiful thing.
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
Matt - 84 Carrera |
Chain fence eating turbo
Don't forget wheel size and tire sidewall height makes a big difference.
I have another thread going about a goose stuck in my front fender (front suspension squeaks) so I've already planned to drop the front this winter and refresh the suspension. Looks like I might as well do the back too. It would be stupid to do just one half of the car. I rebuild my engine last winter, start to finish, in four months. I can't imagine f+r suspension would take longer, or am I dreaming. I've got to get this baby singing so I can drive it to Rennsport next year!!
If you haven't had it apart before, you'll laugh at how simple the suspension is on these cars. Cakewalk.
After doing a complete rebuild of my 3.0 last winter, you don't know how comforting those words are.
Under the radar
How does this compare to Konis? I always felt my Konis were stiff on small imputs, but moved easy on large bumps like dips.
Under the radar
My comment on sways was in reference to the size of your sway bars. If they are larger that could be a source of extra harshness.
I'll measure both sways. I just talked to Shannon at Elephant racing and he said the Boge shocks are inferior quality and feel to the Bilsteins all around. I guess I can put Bilstein inserts up front in the Boge spindles. So that's good news.
Mo money = mo parts
My car came with Boge in the front, which I replaced with Bilstein Heavy Duty inserts. I also installed Bilstein HD in the back. I replaced every rubber suspension bushing with ERP rubber components - every rubber component ERP makes is on my car. My car is at euro ride height (25.5/25 IIRC). Bump kit is installed. I used the DIY triangulation method to corner balance. Pretty new Michelin Pilot Sports.
I find the ride on my car to be very compliant - even surprisingly compliant, but it still feels nicely planted in all street driving.
Greg 86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten 65 Ducati Monza 250 & 66 Monza Junior (project) "if you are lucky enough to own a Porsche, you are lucky enough" |
Bill: Can you share who provides this service? Thanks
RSA Pinky Helga Turtle Carrera Luigi CDtdi |
Here's a dyno plot of a Koni Sport for a Toyota MR2 I found using Google: ![]() The top is compression, bottom is rebound. FYI, "large bumps like dips" is actually probably in the low speed range. High speed is sharper impacts like a section of pavement higher than the previous one, or in the rebound direction a gap in the pavement.
Matt - 84 Carrera |
Bilstein themselves, Elephant, Performance Shock Inc, should all be able to do 911 Bilsteins. Maybe FatCat can if they have the right tool for the front insert.
You aren't going to be able to talk to anyone at Bilstein. Just fill out your paper and send them in. Chuck @ Elephant is the go-to, he was easy to get a hold of. Only negative for me is that he was unwilling to deviate from his canned valving for my requests. He'd do a great job for 99.5% of Pelicans. PSI has been a little tough to get a hold of for me, but I'd be willing to give them a try if I had to do it again. FatCat would be a last resort only for me, ymmv. Relevant needed info would be sprung corner weight, effective spring rate, and motion ratio. Another reason to use Elephant, you just tell them your torsion bar size and your car year / mods.
Matt - 84 Carrera |
