Advice on cleaning up / painting battery area?
The front corner of my 82's trunk/frunk is looking pretty shabby. No real significant rust issues, but definitely some surface rust and corrosion, on the hood as well, and the whole area is pretty dingy. I am wondering how best to treat it as I clean up the whole trunk. This is a driver but I am picky so want something a little cleaner looking. I have read a ton here but can't really decide if I should do por-15, just some satin rustoleum brushed on, or something else. And also I am nervous about painting without totally stripping it down, but it's not worth the time. Any suggestions on whether just doing a little sanding/stripping of the worst rust and corrosion spots, then hitting it with some brush on rustoleum, is going to cause problems later? Thanks in advance!
Overkill is underrated. |
I would wire brush what I can, hit it with an spray on rust neutralizer (Extend or similar), and paint with satin black. Keep doing this every 6-8 months to keep the rust at bay.
Thanks much. Do you think I need to try and do anything to get under the battery mount plate? Is there a way to do anything besides cut it out?
![]() Drilled holes and removed the odd perf plates to get access to that area. Scratched & scraped around inside the "caves"... blew them out... then hosed in good volume of rust reformer swabbing up the flow out. Certainly anything done to preserve that area is better than nothing. .
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
Ah that’s a good idea...agree better than nothing.
Caves Karl?
Now terrified and donning my spelunking gear.....good advice! ![]() Happy New Year guys.
Scott "Houston, Tranquility Base here, the Eagle has landed" Silver 1984 M491 Sunroof Coupe |
Here’s how I tackled it on a later car
Probably easier to just link to the thread ..
Excuse the train wreck of that thread .
I’ll go back and clean it up in the new year when I’m working on the car again .. Finally got my car back !!! |
Here's a thread I started on this topic.
https://forums.pelicanparts.com/porsche-911-technical-forum/1042110-cleaning-battery-area-concerned-about-drainage.html I cleaned the area with baking soda and water, as well as NoCo battery acid cleaner, and then flushed the area out very well. An inspection camera / boroscope let's you poke around a bit and see how extensive the corrosion is or is not. |
The only reason I do not want to acid wash the area is the difficulty in making sure all traces are gone from the nooks and crannies of this area.
wash it with baking soda and water. let dry
pour osphoric acid in there to kill the rust. it wont hurt anything. wire brush it clean then paint with something like POR 15 you can even put a cost of extend on first, then the POR. or paint with WURTHs
cycling has-been
There is a lot of 'extra' sheet metal around the mounting platform.
I'm still getting a small amount of rust flakes out of the corners of the platform so my next step is to drill holes like Discseven did and do the peek-a-boo repair. Bill K ![]()
73 911T MFI, 76 912E, 77 Turbo Carrera |
use
osphoric acid first
Caveman Hammer Mechanic
I use muriatic acic(hydrochloric acid, to remove rust and primarilary zinc and cadmium from steel prior to welding. I store mine outside in a Nalgene bottle, in a plastic bag, the fumes are pervasive. Hydrochloric acid is also a strong degreaser the fumes travel quite aways. You had best douche the surrounding area with a mild alkali solution. The zinc coating on Porsche body panels is very thin and hydrochloric dissolves it almost instantly.
For those not familiar with harsh chemicals be very wary about using anything this aggressive on your car. This is what we use in the aircraft world: ![]() https://www.aircraftspruce.com/catalog/cspages/blkfloatbtm.php?clickkey=10765
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 Last edited by ClickClickBoom; 01-05-2020 at 12:45 PM.. |
Wire brush the rust best you can, vacuum out, brush some Por-15 and be done. Only thing I kind of wish I did was put one of those $2 'battery mats' under the monster battery when it went back in, but no way i am wresting that thing out until it dies.
Scott 1981 911SC Targa - Platinum Metallic |
replace your battery with an AGM battery (which is very resistant to leakage) once done fixing to minimize the possibility of another acid leak
| Tags |
| frunk trunk paint |
