Insert Tag Line HERE.....
rattlsnak's Avatar
What size wheels on SC?
Anyone know if 275/40 17s fit on the back of a stock SC? Tire Rack recommends 255s, I couldnt fit anything larger than 245s on the Fuchs. These are mounted on the C2 Turbo replicas (Millie Maglias from Tire Rack which i am trying to sell) with the correct offset for the pre 89 cars.
Thanks..
Old 02-03-2003, 12:00 PM
Senior Member
Superman's Avatar
It all depends on the offset. There are those here who will have excellent information for you. All I can contribute is that there is generally plenty of room. I believe that the killer setup is 7" Fuchs in front and 9" Fuchs in back. With tire sizes in the neighborhood of 255 (back) and 215 (front). This is an improvement over stock ("sport") configuration in several ways. More grip. Better match between wheel and tire size. Bigger Biceps. etc.
Mocha 1978 911SC. "Coco"
Old 02-03-2003, 12:07 PM
Got Boost?
IMONBOOST's Avatar
You have to re-route the oil lines and grind some trailing arm's screws. That's what I was told, I believe JackOlsen is the expert on this.
"The only motivation to make you go race after race, travel after travel, is winning. The possibility that you have for winning. If you don't have that, nothing else can make you work."
-Ayrton Senna-
Old 02-03-2003, 12:08 PM
slammed1000's Avatar
Send a message via Yahoo to slammed1000
what size wheel? it is very close on a 9.5 inch wheel. oil lines are in the way and need to be moved and the bolts on your spring plates come in contact also. you can gring the head on the springplate bolts for added clearence and add spacers to move it out a little. just experienced this last night so i know first hand!
Old 02-03-2003, 12:36 PM
Bill Verburg's Avatar
275/40x17 on 9.5 or 10" rim is about the physical limit. Here is a pic of the relocated oil lines(into the crease) and ground down trailing arm bolts
In addition the lips needed some serious massage.
This one shows the minimal(but sufficient) clearance at the bolts
The other issue is the rather larger height of the tire and its effect on gearing. For track use this is not a problem, as the increased size of the friction circle overall more than compensates for any gearing degradation, but it will affect performance in the stop light wars.
A nice compromise is the 265/40x17 made by several vendors.
Bill Verburg
Old 02-03-2003, 12:57 PM
rattlsnak's Avatar
Thanks guys, they are on a 9 inch wheel. See this.. http://www.tirerack.com/upgrade_garage/WheelSearch.jsp?&autoMake=Porsche&autoModel=911SC+Coupe&autoYear=1978
They are the Millie Maglia Cup 1s.
The difference is, I had the 275 rears on my turbo bodied car and had to use a 1" spacer, but someone who is interested in them is asking if they will fit onto an SC car.
Marc
Old 02-03-2003, 01:03 PM
Elombard's Avatar
I will bring my SC body car over and see if they will fit :-))
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 02-03-2003, 01:50 PM
Send a message via ICQ to old_skul
Rattlsnak, you have to sell those to me. Not only do I work for a DCI carrier as well but I also am a pilot. I hope you're asking because I have a carerra
Mark Szabo
1986 911 Targa 3.2 (I will miss you)
1985 Scirocco 8V (I will not miss you)
1986 Dodge B150 Ram Van (I can't believe I got $200 for you)
1987 Escort 5-speed 1.9 RIP
Old 02-03-2003, 01:57 PM
Eric Mckenna's Avatar
Come on Rattle! Sell the wheels to Mark(old_skul) ya goota...
Eric
Famous last words..
"Hold my beer and watch this...'
" The reason the Irish are always fightin one another is that there are no other worthy opponents ".
Old 02-03-2003, 03:12 PM
rattlsnak's Avatar
Mark, I didnt know you worked for DCI, or that you wanted the wheels. Although by your town, Im assuming its "the OTHER" carrier. ! I posted the ad yesterday, and have had a couple people respond, but no one has said, "I want them" as of yet. That would be cool though, I could put them on a flight up to CVG from ATL ! On second thought, knowing our rampers,. Nahhhhh... They would end up in Az. !
Marc
Old 02-03-2003, 03:19 PM
Rattle,
I really think ya should sell them to Mark, He is a good guy, and he'll run the **** out of them for ya on thetrack.. hahahah! Mid Ohio is comming up and he could use some nice wide track wheels.. HAHAHA
Eric
Famous last words..
Old 02-03-2003, 03:40 PM
rattlsnak's Avatar
Well, its up to him at this point!
Marc
Old 02-04-2003, 10:11 AM
We actually have ACA, ASA, *and* Comair flights here in Cincinnati. Comair is the dominant though. We try to do a good job and play nice with the other carriers though...Delta sees to that.
Yeah, Rattl, I'm interested. I need to know for sure though if they'll fit under my fenders, with or without spacers. What kind of tires are on them?
Mark Szabo
Old 02-04-2003, 10:17 AM
Mark if they are aftermarket wheels and he has them on his car.. they will bolt right up to your 86.... I'd have to say that they are standard 7" front and 9" rears..x17"
Famous last words..
Old 02-04-2003, 11:04 AM
rattlsnak's Avatar
They have the BF G-Force R1 Comps. (track tires) 225 fronts, 275 rears. The picture is on the for sale thread.
Marc
Marc
Old 02-05-2003, 05:59 AM
hahah I know .. I am simply putting the pressure on him for ya! HAHAHA
he is going to need them to post better track times then me this spring. HAHAHHA
Eric
Famous last words..
Old 02-05-2003, 06:12 AM
expat's Avatar
Bill,
I know you've probably been asked this a million times, but I'm being slack avoiding the search...do you use spacers for that size...if so what size?
Second, what was your method of 'massaging the lips'?
Mark
'87 911 3.2ltr Cab. ROW (sold )
'90 964 3.8 ltr C4 Coupe (P-Dealer built, track prep'd, sold ) )
OMYG..I'm Porscheless
Old 02-05-2003, 07:18 AM
If it helps, I have these exact wheels (Mille Miglia C2T from Tire Rack, 7.5x17 and 9x17) on my '88 Carrera, with 215-somethings on the fronts and 255/40-17 rears. No spacers or rubbing, and I only had to roll the front lips.
Old 02-05-2003, 08:15 AM
