The sway bars are weltermeister, i'm not sure if they had much for size options back in the day. They seem to be about 3/4" diameter, but i'll try to measure soon and also get coil sprint rates.
Cheers, Chris 1986 951 SOLD: 1975 Carrera / 965 tribute w/ 1989 3.3 turbo 8.5:1, custom Evergreen K27 7200, 964 cams, euro CIS, TEC1 dual plug, rarlyL8 headers & hooligan pipe.
Counterclockwise?
Chris. I'm driving an 86 911 Red with turbo twists and my name is on the car. Usually parked in the same general are as you, but I don't think we've met.
Loosen up your sways and lean how to adjust them before the track day so you can make adjustments at the track if needed. I'd adjust them at the track where you have gone to far, and then dial them back. Your car should understeer. Aim for the apex and let the car understeer so you just clip it. Maybe you are overthinking it and it's just the sways or tires. Or maybe you are not as good of a driver as you think you are.
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
Hi Rod, I'll come introduce myself! And I certainly don't think i'm a great driver, i'd like to be, but so far i'm just good enough to get into the Black run group but i'm the greenest black at this point.
![]() I'll bring tools for adjusting my sway bars, its pretty simple.
