Can I reuse this gasoline?
As an emergency measure I had to drain my gas tank - broke a hose while changing the fuel pump. I collected the gas in a construction-grade trash bag inside a trash can. The bag was intended to keep the gas as clean as possible.
Can I reuse this gas? If so I'll scoop it and pour it back into the tank through a funnel. Hate to waste 12+ gallons.
But not sure what being stored in the trash bag will do to the gas.
1972 911 wide body - Estelle
Old 09-16-2017, 08:53 AM
High Life's Avatar
Minimize your risk in reusing by filtering it through a t-shirt (t shirt wrapped over a funnel) and then use the gas in your lawn mower not your Porsche.
1981 911SC
Old 09-16-2017, 08:58 AM
Not ideal. But perhaps best to be safe. Not having a lawn mower, I'll need to figure out how to dispose of it, if it comes to that.
Old 09-16-2017, 09:24 AM
newb.
eimkeith's Avatar
I'd put it in the truck.
keith
'75 RS/RSR-look | '73 CB750 | '70 TD250B
r gruppe #436
Old 09-16-2017, 09:31 AM
Vulnerari Praesidio
Know anyone that drives a Kia?
"Wisdom is knowing what to do next; virtue is doing it."
- David Starr Jordan
Old 09-16-2017, 09:44 AM
You may find it very difficult to dispose of the gas legally. Where I live it is next to impossible. If the gas is fresh and you have a line filter why not put it back in the Pcar?
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 09-16-2017, 12:07 PM
Fleabit peanut monkey
Bob Kontak's Avatar
+1
Use the t-shirt for the primary filter. Put it in a bucket to see it's condition, though. If not clean as a whistle, get rid of it.
1981 911SC Targa
Old 09-16-2017, 12:14 PM
'73 911 T Targa
I drain the leftover gas from my boat every year. I put it in my truck a quarter tank at a time and fill the rest of the way with fresh gas. I figure it's best to use it in something that will burn through it quickly.
Assuming it's got ethanol in it, be careful to not let any water get in it. It can lead to phase separation, then you've got a real disposal problem.
Old 09-16-2017, 12:39 PM
Chain fence eating turbo
As long as it's clean and hadn't sat out so long that it gets "stale" or pick up moisture, I'd use it.
Old 09-16-2017, 12:42 PM
I reused some of the gas. I figured whats the difference between a plastic gas can and a Home depot bucket, besides the lid and vent. Filled it, covered it and poured it back in an hour later. Looked very clear. had another batch in another container that started getting cloudy; did not reuse that.
Thanks for the advice.
Old 09-16-2017, 01:16 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
12 gallons of gas sounds like a righteous youtube video. Post quickly before the cops get you though....
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 09-16-2017, 06:58 PM
