Bizarre Headlight Problem
Just recently, when I turn on my headlights, the wipers turn on with it. Sometimes the wipers will spontaneously turn off, sometimes they stay on until I turn the lights off.
I have LED headlights, but they've been in for over a year and it's never happened before.
Has this ever happened to anyone else and how in the world would the two even be related?
1986 911 3.2 Cabriolet
"We all have a desire to create something that will show we were here. " Ferry Porsche
Old 09-24-2017, 11:41 AM
Had a similar problem with the wipers coming on sporatically, except mine did it when I used the turn signals. Did a lot of trouble shooting with a power probe, and found it was a ground loop problem. The cause was
a poor ground on a corroded wire in the "wire stack" located under where
the battery negative cable mounts to the body. Cleaned up all the connectors and the problem was fixed! Take a look, clean up the connectors and you might fix it. Ground loop problems can cause many
unexplainable things.
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 09-24-2017, 12:57 PM
Ahh, you know, I had removed an old stereo wire from the big negative mount near the battery a couple of days before I noticed it! I could have messed with the connections without realizing it.
I will definitely start there! Thanks for the tip!
Old 09-24-2017, 01:43 PM
That was it! Cleaned up the connectors on the main ground terminal and all is right with the world of headlights and wipers!
Old 09-25-2017, 02:52 PM
