Cory M's Avatar
Boge strut question
Ordered some Bilstein HD inserts for Boge struts. They arrived with a different style cap / wiper seal (external vs internal thread). Anyone have a source for the correct caps? Looked at a few places online and no luck yet. Thanks.
Old 06-27-2019, 12:32 PM
What year is your 911? The late1985 model year had two different styles. Early and late models.
But since we don't know what year you have advice is 100% guess.
Old 06-27-2019, 12:49 PM
Cory M's Avatar
I'm pretty sure the struts came off an 88 Carrera.
Old 06-27-2019, 01:06 PM
The 9 Store
They usually come with both types of caps. I would call Bilstein and ask for the correct ones. I've given away my extras or I would send you some.
All used parts sold as is.
Old 06-27-2019, 01:35 PM
Cory M's Avatar
Thanks, I'll double check the box and follow up with Bilstein if they aren't in there.
Old 06-28-2019, 07:34 AM
Registered Minimalist
75 911s's Avatar
Curious, this looks like the right one for my midyear Boge that I replaced. I didn't know the caps come off. So isn't this for the early Boge strut with 3" caliper spacing? Do the Carrera Boge struts have 3.5" spacing?
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 06-28-2019, 07:38 AM
Cory M's Avatar
yes 3.5" caliper spacing
Old 06-28-2019, 07:54 AM
75 911s's Avatar
Early Boge Bilstein strut, like the one shown in the top picture, is part #34-001127
The Carrera Bilstein insert for Boge strut is part #34-001141
What is the part #on your invoice? or the insert?
Old 06-28-2019, 08:11 AM
KTL KTL is online now
Schleprock
KTL's Avatar
I believe it's the later struts that have the external threads as shown in the pictures. My '87 and '86 911s with original Boge struts both have used the Bilstein nuts that are female thread (struts with external threads as pictured) when installing new inserts.
Cory,
I have a set of good used Bilstein inserts in the basement that were "discarded" by a friend's shop when he had the Boge struts converted to JRZ. I'll look at those inserts tonight and see if I have the nuts are still with the inserts.
Kevin L
'86 Carrera "Larry"
Old 06-28-2019, 01:28 PM
87 - 911
Here is a picture from my HD conversion a few years back, yours have a different style of nut. I don't recall mine coming with anything else.
Old 06-28-2019, 06:40 PM
Schleprock
KTL's Avatar
Cory,
Here’s my set if you want them. Unfortunately Tim zipped them off with an air hammer and mangled the tool slots. Which also boogered the scraper seals a little bit. Tim runs a shop and seems most anything he takes off the cars is expected to be junked
I’m sure if you call local Bilstein they can set you up with what you need
Kevin L
'86 Carrera "Larry"
Old 06-29-2019, 05:35 AM
911timesThree
rolfjahn's Avatar
My 1988 Carrera Struts have the external threads
1987 911ST 3.4L G50 LS 20/21 Granite Green Hot Rod
1988 911 3.4L G50 LS 20/21 Guards Red Hot Rod
2020 F87 M2 Comp 6Speed Carbahn 562/567
Gone: 1991 965 Black/Black Turbo
Gone: 2002 E46 M3 6Spd CSL style build
Old 06-29-2019, 09:38 AM
Cory M's Avatar
Thanks Kevin! I'm actually only a few miles from the Bilstein warehouse. They aren't really set up for walk up customers, but I'll see if they can help. I'll let you know if that doesn't work out. Thanks.
Old 06-29-2019, 01:27 PM
Cory M's Avatar
Problem solved. Confirmed that the inserts Bilstein originally supplied were for an early model, exchanged them for the correct later Carrera inserts. The dampers were identical but the caps are different and no one seems to list them separately. Thanks to all who offered support!
Old 08-10-2019, 02:11 PM
The 9 Store
Strange. When I order them from our distributor, I get both types of caps in the box.
Old 08-10-2019, 05:49 PM
Schleprock
KTL's Avatar
Sweet. I'm glad you didn't need my gnarly mangled spares.
Kevin L
'86 Carrera "Larry"
Old 08-13-2019, 08:50 AM
Cory M's Avatar
Me too, but I appreciate the offer!
Old 08-13-2019, 09:21 AM
Porsche Owner
mark4ton's Avatar
I need a pair of those. Anyone on this thread still have an available pair or can help me get a pair?
Old 01-21-2020, 08:21 AM
I had to do the same with my Upgrade to Bilstein sport inserts to Boge strut. I order my caps directly from Bilstein.
Old 01-21-2020, 08:26 AM
Porsche Owner
mark4ton's Avatar
I contacted bilstein and they said they wont sell directly to the public.
Old 01-21-2020, 01:56 PM
