Jacksonville, Fl
Is a rear window seal replacement THAT daunting????
Hey Gents,
My recent 'refresh' on my 88 Carrera is nearly complete, with the exception of replacing my front windshield and rear window seals.
I decided after searching this site and asking a few others that this was something I was going to farm out and not attempt by myself.
Problems is, no one in my area will attempt the rear window seal replacement on my car due to the difficulty of routing the defrost wiring to get the seal set correctly.
I have tried 2 reputable Porsche mechanics here in Jacksonville, (Seth at Technical Dimensions and Frank Eisenman at All Euro) as well as my body shop and a glass company off their recommendation. And no one is willing to take on the task. I wasn't comfortable doing this job before and certainly aren't now, considering what these folks are saying.
For those of you who have done this or had this done, are there any recommendations of shops that have experience doing this in North Florida? Is it really as difficult as they are making it out to be? (Is this a 'white unicorn' project, or are these guys just too busy to do something thats just tedious...?)
Thanks for the advice... Alex
Alex
Jacksonville, Fl
'88 Carrera, Guards Red
Old 09-19-2017, 11:40 AM
notmytarga's Avatar
If I can do a (no leak, well positioned) Targa seal using great advice here from the Pelicans - you can do a coupe.
75 911S Targa - Mine from 2001 until sold to Germany buyer 10/2016
<ALL DIY> Brakes/Wheels '01, Body/paint/restoration 7/04, Suspension 3/07
Engine rebuild - done 7/08 - added 28 tube cooler and SSIs - running strong. Ducktail painted.
2021 MachE, 2012 Outback, 2019 Crosstrek, 2018 Impreza wagon
Old 09-19-2017, 11:48 AM
Originally Posted by aread View Post
Hey Gents,
Pretty sad... but this seems to be the common denominator for everything in the service industry these days. It seems the 'least work I have to do...the better' is the current moto for today's standard of customer service.
1987 Porsche 911 Carrera Coupe
Old 09-19-2017, 12:01 PM
Jacksonville, Fl
Originally Posted by Trakrat View Post
Pretty sad... but this seems to be the common denominator for everything in the service industry these dats. It seems the 'least work I have to do...the better' is the current moto for today's standard of customer service.
Agreed. At this point I'm happy if they just return my call....
Alex
Jacksonville, Fl
Old 09-19-2017, 12:18 PM
wayner's Avatar
Jack did a nice one man write up if you can find it here
SOLD - 914 wide body hot rod
Old 09-19-2017, 12:24 PM
More Likeable IRL
juanbenae's Avatar
check the home made by jeff youtube channel. he has a thread here documenting his build and he struggled with his windows some. check those episodes of his build video series as he has some great tips. like the authentic Porsche rubbers are far better than the repros.
jeff is MDX here I believe.
Old 09-19-2017, 03:22 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Did it by myself, with the help of an ATV tire and large rock. The wiring is about as difficult as remembering what hooks up to what. Invite a PCar buddy over and do it. Mine took about 2 hours solo....
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 09-19-2017, 03:32 PM
Jacksonville, Fl
I'll have to check that one out. Thanks!
Alex
Jacksonville, Fl
Old 09-19-2017, 03:44 PM
We do those all the time, unfortunately Fort Worth is a little far for you. Be sure to find the plug for the rear defrost back at the rear of the relay board, take the plug apart and remove the wire ends, then the whole harness pulls up thru the rear deck. DO NOT cut the wires and use butt connectors! The glass should be removed either by levering the rubber back over the frame edge if the rubber is still pliable, or cut the edge off but always pulling the glass and trim out together. DO NOT pull the trim from the rubber !!!You will bend it!! Place the glass on a saw horse trim side up, then pull the rubber away from the trim,,,,,DO NOT touch the trim. Take pictures of the wiring and the cuts in the rubber to allow room for the spades,,,,,pay close attention as to which groove is for the rubber and which goes around the glass. USE ONLY Porsche rubber, not a place for aftermarket. DO NOT push the trim in the new rubber,,,,use a good lube like Wurth clear silicone lay the trim on the rubber and OPEN the rubber to accept the trim,,,finger force only on the trim. Roping it in is the easy part.
Old 09-19-2017, 03:48 PM
Checked out
McLovin's Avatar
Easy to do on a coupe.
Good tips/advice from Ed, above.
Old 09-19-2017, 03:58 PM
autojack's Avatar
Shop near me, 40 years working on Porsches, the owner said it's about a 50/50 chance that the glass shatters trying to remove it. When HE does it. PO thought the seal on my car looked iffy so he bought a new one and gave it to me with the car. But this mechanic said, if it's not leaking, just leave it alone for now, so that's what I'm doing.
Old 09-19-2017, 09:09 PM
Recreational User
porschenut's Avatar
It was his writeup that convinced me to replace the rear window seal on my 88 coupe myself. My install went even more smoothly than his. Yeah, the defrost wire routing was a little tedious, but not a big challenge.
Old 09-19-2017, 09:25 PM
I've got the same situation going on. Was going to replace my windshield and rear window seal and had a new windshield. Went to get it out of storage and noticed it had a small chip on one side. Out in the sunlight there was a crack about an inch & a half long into the windshield, so now I needed another new one. In looking around for a place to buy one, I talked to a Pcar guy who suggested I call some of the local, independent Porsche shops to see who they used. I located a guy that way & decided to just have him install both front & back. Not cheap & I have to supply the rear seal, but the actual windshield will only cost $60, which is a fraction of what I expected to pay.
Marv Evans
'69 911E
Old 09-19-2017, 09:40 PM
Spiderman
Jesse16's Avatar
Even in the small town I live in, the local glass shop had no real problem that I remember installing mine after car was painted. I got all new rubbers from Pelican. Find a shop that does glass in hot rods and older cars who have more experience with gasket held glass vs glue in. Since my paint job, I've found another shop that is in that category who seems to be the only person who can get 911 windshields without a problem.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 09-20-2017, 04:10 AM
Jacksonville, Fl
Exact situation here. when I bought the car the PO handed me seals and trim and said, "I never got a chance to get these in". Now I understand why...
Alex
Jacksonville, Fl
Old 09-20-2017, 04:25 AM
It's not that bad. It is a challenge to do by yourself but if you can have some help (ideally one person in the car and one on each side on the outside to keep pressure even and hold steady while you make the connections) it is definitely doable. The front is pretty easy comparatively so you could always start there and see how it goes/get a feel for it before you cut out the back.
a little of this + a little of that
Old 09-20-2017, 04:26 AM
Jacksonville, Fl
Jesse, I have a place just south of you, and was thinking about opening my search to include NC when Im back up there in a few weeks. Can I ask, which shop did yours?
Alex
Jacksonville, Fl
Old 09-20-2017, 04:28 AM
Jacksonville, Fl
Having trouble finding his write up, does anybody have a link or his user name?
Alex
Jacksonville, Fl
Old 09-20-2017, 04:31 AM
I agree. If you've done a front windshield successfully then use Jack's writeup for a successful rear installation.
X2.
Old 09-20-2017, 05:11 AM
That Guy
Techno Duck's Avatar
I need to replace both front and rear seals also. Front seals have been out in the sun too long and the rear seal looks like it shrunk, also from sun exposure. Ive got a lead on some places near me that are willing to do it.
Is replacement rear glass relatively easy to source (just in case)? I don't mind replacing the windshield as its got some pitting.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 09-20-2017, 05:15 AM
