So, 5th won't engage...
Had the car out for an autocross test and tune today and put a LOT of runs on it, maybe 30 which is almost a full season in some parts. Of course in autocross you typically only use 1st and 2nd, actually pretty much just 2nd.
Heading home car would not go into 5th. Reverse is no issue. It mostly feels like the synchros won't align properly. You can sometimes kinda get it into fifth but it pops out. All other gears seem fine, so I don't think there is a catastrophic failure. I don't suspect a shifter or coupler issue in this case, though of course I'll try that first.
I assume the only good answer is "crack it open and have a look" but is it plausible that the 5th gear synchro can fail without the actual use of 5th? This thread is the closest I can find to a matching issue, and there's no closure in it.
Final question - I've pulled a motor before and done a clutch, how fiddly is trans work? The exploded diagram is pretty intimidating. But it does look fun.
Matt - 84 Carrera
Old 08-26-2017, 02:18 PM
Matt,
First, just check the grub screw on the shift coupler hasn't loosened off.
I had exactly the same issue on my 915 until I noticed the coupler wasn't tight on the gearbox shift shaft. A tweek of an allen key fixed it!
Old 08-26-2017, 03:12 PM
Member 911 Anonymous
DRACO A5OG's Avatar
Check the Shift Coupler then under shifter on those bushings, last would be gear box mounts ( unlikely but if they wear out it would mis-align the input shaft. )
'85 Carrera Targa
PCA/POC
Old 08-26-2017, 03:14 PM
So allen key / coupler adjustment didn't help so I dropped the motor out today.
The dog teeth look pretty good I think:
Tapping on the shift thingie with a mallet gets it that far. Is that fully engaged? Can't get the darn camera to focus on the right spot. In the car it feels like it doesn't fully get into 5th and it pops out.
Matt - 84 Carrera
Old 09-02-2017, 12:26 PM
Better shot, this feels like a hard stop on engagement. Should the slider get all the way to the step on that dog ring?
Matt - 84 Carrera
Old 09-02-2017, 01:00 PM
Inside of slider looks munched:
Synchro:
Without really knowing how it's supposed to work looks like the deformation in the teeth on the slider prevent the gear from fully engaging. How the slider teeth got that way I don't know. Trans was full and gear oil still looked new.
Matt - 84 Carrera
Old 09-02-2017, 05:00 PM
gearhead
I'm not seeing anything wrong with the components themselves. I think you have an issue in your shift rods and detents. Something isn't letting that slider drop all the way onto the gear, and it's not at the gear itself. Now that it's apart I bet it pops right onto the gear.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 09-02-2017, 05:05 PM
Is the slider supposed to make it all the way to the "lip" on the dog ring? Because it doesn't feel like it really snaps into place fully either with or without the shift fork on.
Matt - 84 Carrera
Old 09-02-2017, 07:57 PM
Under the radar
Trackrash's Avatar
Engage one of the other gears to see how it should work and look when fully engaged.
Gordon
'71 911 Coupe 3,0L outlawed
Old 09-02-2017, 08:19 PM
gearhead
I've got to go to the shop tomorrow. I'll snap some reference photos.
1974 914 Bumble Bee
2009 Outback XT
Old 09-02-2017, 08:23 PM
Thanks guys. I don't plan on cracking the center portion of the gearbox at this time, so can't really compare to the other gears. I also noticed a very slight amount of play in the lower gear. Not a lot, but I would expect it should be rock solid on the shaft?
Matt - 84 Carrera
Old 09-03-2017, 07:53 AM
Under the radar
Trackrash's Avatar
You can remove the bottom plate. You will have access to the gears. You will also be able to check to see if the guide fork is secure.
Gordon
Old 09-03-2017, 03:50 PM
Take the gear apart and check the brake bands and anchor blocks. Saw a post a couple of days ago the op could not engage a gear and his anchor block was jammed into a locking position. Don't know why or the outcome.
Old 09-05-2017, 10:36 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
I am far from an expert here but this looks like that slider was killed with a bad shift. The teeth show heat damage and are flattened and that's why it doesn't go into gear. This happens when the synchro bands can't match speeds during the shift and instead the friction super-hearts the teeth. They become soft and mushroom when trying to engage the gear:
I did this to my third gear with a badly missed shift (clutch pedal not fully depressed while trying to force it into third) and had the exact same effect. Replaced the slider and the syncho bands and all was good.
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 09-05-2017, 01:16 PM
That's what I was thinking. My Dad took the car to lunch and said it wouldn't go into 5th. Who knows how hard he tried but I know I tried a few times to get it in there too. Already ordered a replacement slider. I guess my big concern is what caused it in the first place.
So I assume I should also replace the synchro band, if it got hot enough to cook the teeth it cooked the band.
Matt - 84 Carrera
Old 09-07-2017, 05:29 PM
ischmitz's Avatar
If the clutch wasn't fully depressed or he speed-shifted into 5th that'll do it. The friction heats up the teeth and makes them soft. These transmissions need to be shifted with a bit of care to give the synchro time to do its job.
Old 09-07-2017, 06:02 PM
New gear/slider popped all the way in. Plan on replacing:
Needle bearing and whatever associated "bushing" is
Brake band
Nut
Gasket
Sound good?
My Dad is pretty gentle with the car. Any chance a little bit of play from a failing bearing could've lead to the failure? I'd rather not nuke another slider...
Matt - 84 Carrera
Old 09-09-2017, 04:58 PM
Plays with cars's Avatar
Matt, I will reinforce what others have suggested: check all of the bushings, set screws and adjustment throughout the shift linkage. Its shocking how a little bit of slop or misalignment is amplified through the linkage and can compromise complete engagement.
Mark B
'73 911S (long term ownership) '70 914-6 (long term project) '74 914-2.0 (sold)
Old 09-10-2017, 09:01 AM
Yup will do, have already had a good look at the coupler and there's no play in that. Thanks for all the help pelicans.
Matt - 84 Carrera
Old 09-10-2017, 05:11 PM
Just for closure: replaced the slider, also put a fresh roller bearing and bearing sleeve, and a new synchro band. Broke my cheap c-clip pliers in the process.
Got the motor / trans back in the car in just under 2.5 hours today and drive the car around. All is well again.
Thanks pelican for all the help and most importantly the courage to dig into the trans myself. Special hat tip to Pete Z for his great article series.
Matt - 84 Carrera
Old 09-20-2017, 06:49 PM
