Sway Bar Upgrade
As I am trying to put together my suspension upgrade, one thing to consider are changing the sway bars on my 83' SC. From what I have read, it seems that a lot of people simply go with a sway bar from the 3.2 Carrera as an upgrade.
I will probably use Elephant Racing for many of the bushings, torsion bars, shocks, etc... Elephant Racing also sells a Hollow Adjustable Sway Bar System for my car. I am wondering what the difference is between the 3.2 Carrera sway bar & the Elephant sway bars, and if it is worth it. I will in all likely hood not track my car, but I do like to let it fly on the back roads on a regular basis. |
The sway bar from the 3.2 isn't adjustable. besides that, a 30 year old sway bar is probably not going to be in the greatest condition. |
If you aren't going to worry about adjusting the bar, the factory 3.2 is a little thicker than original and a simple replacement. Since getting 10/10ths out of the car isn't your real goal, save time and money?
What torsion bars are you going to upgrade too? What handling characteristics are you hoping to improve upon? All of these pieces need to work together towards your goal after all. |
The Carrera bar is probably the way to go. Unless you are going for the ultimate. In that case along with a torsion bar, bushing and shock upgrade you would most likely change to a through body adjustable front sway.
Aren't the 3.2 Carrera sway bars available new through pelican or other sources? |
FYI, I don't think they went with the bigger sway bars till 86, one year before the G50..
Carrera sway bars.......
Tony |
on another note, across the 3.2 915 gear box run they were equipped with the fortified 915 side plate. if you are doing transmission work it is a great upgrade for the 83 & older 915s. |
86 is the year Porsche upsized the swaybars, which carried onwards to the 87s to 89s with the G50s.
Another consideration is the new swaybars coming out from Eibach that fits into the factory mount locations. They are significantly beefier than the 86-89 bars without any of the harshness of solid mount/monoball links. The rear bar is three hole adjustable. Eibach installed a set on my stock '86 and the car corners noticeably flatter with less set time needed between transitions. |
I called Eibach and the gentleman I spoke with said that they did not sell a set of swaybars that would fit my 83' SC. He said the only set of sway bars that Eibach sold for a 911 were for the years 99-04. Do you have a part # for the set of sway bars that they installed on your car? Or is there someone at Eibach in particular that I should ask to speak with who knows what sway bars were installed on you 86 that would also work on my 83? Thanks |
Undermount sway bar? The hassle of removal and replacement sort of negates any advantage provided by a larger diameter. And the drop links are fixed length, compromising potential corner balancing. However, it's probably the most economical option.
A more valid upgrade would be to install a through-chassis sway bar, the type used on earlier 911s (pre-911SC). However, these will require access openings in the chassis sheet metal and reinforcement plates to strengthen the sway bar mount. This would be offset by the fact that adjustable sway bars provide a range of understeer adjustment as well as provisions to accurately corner balance the vehicle via the adjustable drop links. Sherwood |
The bars AFAIK won't debut until mid October this year, so that is probably why it's not officially in their catalog yet. Both Ryan, and Christian Sebralla - VP Operations , both of who are members here on this forum, know best as to their timeline. There's another thread here with Eibach's Eibachtoberfest event on October 14th that will debut the new bars. Hopefully it's ok with them if I post some limited 'spy' info and data on them. The final specifications and such may be subject to change and/or further refinement so take my info for what it's worth. The factory bars from my 86 and an 87 were provided to them to 3D digitize their shape and profiles, which which were analyzed and a new set of bars were re-engineered and test fitted to go exactly into the factory underbody mounts and end attachment points on the suspension arms, with no alterations or drilling of the chassis or ancillary parts of any kind. The goal of the bars is not to create another set of track/race car bars, but to develop a set of drop in bars for improved street and sport performance, what 90+% of owners are Everything is engineered, fabricated, manufactured, and installed in house in their massive 150,000 sf facility - which is impressive and state of the art. A whole episode of 'How It's Made' could be produced just at this facility. They produce the suspension products such as shock, sway bars, and springs for many of the OEMs, such as Toyota and Ford Motorsport, and smaller aftermarket business such as GMG etc.
Anyways I digress, but I am told the overall design is that the front bar is 70% stiffer than the 86-89 factory bars, and 67.5% stiffer in the rear while being 3 hole adjustable. The front bar is 24mm while the rear is a hollow 25.4mm bar. As mentioned, no drilling of the front wheel wells or welding of mounts to the control arms. This is better for cars that prefer to preserve originality and value. I have Smart Racing 31 and 27s on my other 3.2 that I have for track use, and they are fantastic, but I would be reluctant to hack up what is my original stock 86 to install those. Regarding removing any sway bar preload, I suppose you could replace the rear drop links with adjustable ones, or just shim one side or the other of the bar mount down if needed. http://forums.pelicanparts.com/uploa...1505931482.jpg http://forums.pelicanparts.com/uploa...1505931491.jpg http://forums.pelicanparts.com/uploa...1505931537.jpg http://forums.pelicanparts.com/uploa...1505931547.jpg |
Sorry our rep misinformed you. Word on what we have in R&D or "in the works" doesn't always make its way to our sales team as it should. I have an 82 SC and I am very excited about these. Ryan |
The whole purpose of sways is to tweek the handling, not make gross changes in it. |
Sherwood |
Oh neat that front bar at 24mm is going to be the new biggest available underbody front, displacing the 7/8" (22.22mm) Addco.
Bigger not necessarily better. Depends on your operating conditions.
Thanks again |
Ride harshness is definitely a consideration, so this is useful information. Thanks for speaking up. Jason |
As always, I appreciate your knowledge and expertise. Thanks myslateblue911 (jason) |
I'm yet to experience any downsides with this combo, it corners flatter whilst straight line comfort is OEM quality. My small brain was thinking larger torsion bars would hurt ride more than larger sways as the latter only come into play on corners, whilst stiffer torsion bars would be constantly firmer? |
Also not an expert, but my thought process was similar to sp_cs...^^
The set of genuine RUF sway bars (23mm front, 22mm rear) I have fitted to my 88 3.2 Carrera are made by Eibach, so I find it strange that Eibach R&D are re-engineering these bars from scratch.
Whilst I agree that bigger is not always better, I find the 23mm front/22mm rear bars, in combination with the standard TBs and Boge shocks, are the perfect set up for a primarily street driven car. Not harsh at all. http://forums.pelicanparts.com/uploa...1505990895.jpg http://forums.pelicanparts.com/uploa...1505991121.jpg |
I hear you guys and don't dispute your driving experience. Perhaps I was/we were comparing apples (through-body sway bars, my history) and oranges (undermount sway bars).
It has been reported that Porsche 911 SC/Carrera undermount sway bars don't provide an ideal geometry for roll stiffness (compared with "apples" above), as though supporting a through-body sway bar with chassis sheet metal is ideal (no). Nevertheless, when larger undermount bars are discussed, the resultant ride apparently isn't the same as a through-body bar of the same size. Please proceed. Sherwood |
Ryan |
I've lightened my '83 SC and upgraded to the Carrera sway bars and am extremely happy....it corners flat and the ride is not harsh.
I kept the stock rubber when rebuilding the front suspension/stock T bars but have adjustable arms in the rear with a poly bushed T bar. Great road set up......lots go too far and end up losing their fillings on less than glass smooth roads. |
I have perhaps 200 miles on the new Eibach bars and I would be hard pressed to perceive a difference in the ride between stock and these new bars. There's no noise or vibration from them. It could be that the are mounted in mild durometer bushings and that the increase in stiffness is not that extreme. Besides a stock suspension I think they would also make a nice complement to an upgraded torsion bar setup such as 22/29s.
Regarding the front undermount setup, other than lack of adjustability it seems to work fine. It's pretty much how the front bars are mounted on the 996s, 997s, Boxsters and Caymans and works for them. Bending a bar with higher arms and multiple holes with a drop link to the strut body or control arm, yeah that would be the cat's meow. |
We actually ended up with the higher front bar, drop links and two way adjustable. After we finished Steve's car we tried the bars on Steven's SC and realized that the install is too difficult (last week). We will need your car back to install the latest bar. The 78 - 89 bars as well as the 964 bars are going in production right now. We are still looking for a 993 to fit a set of prototype bars. Christian at Eibach |
Well meow that is fantastic news! I did get a comment by one shop asking what was the purpose of an upgraded bar was if it wasn't adjustable but seems you've addressed that! I will contact you by email.
Jim (Draco on this forum) told me there is a midway angle on the front control arms where the stock sway bar pops right in with no force. It's not at full droop such as up on a lift, or compressed such as when parked on a alignment rack but somewhere in the middle. |
Are you producing bushings for these as well, or is there an existing OEM bushing that will fit?
rock crawlers have front sways that disconnect quickly so each wheel's suspension can act independently when crawling. those bars do look delicious though!:) |
Steve, I am sure I am misunderstanding you when you say...."I have perhaps 200 miles on the new Eibach bars and I would be hard pressed to perceive a difference in the ride between stock and these new bars..." My question is, if that is the case then why change out the stock swaybars to begin with? Another question for you. Are you familiar with Elephant Racing's Hollow Adjustable Sway Bar System? If so, what would be the pro's & con's when comparing ER's sway bar vs. say the Eibach sway bar you have mentioned. Thanks |
I was afraid my description might be misinterpreted. What I meant was with respect to a degradation of ride quality or any increase in noise, vibration, or harshness (NVH) in comparison to the stock bars, in straight line driving, I don't really notice that much difference on the street or freeways here in Los Angeles. If the road surface though were so bad such as to cause the car to rock side noticeably, then I think you might feel it as rocking the car firmer because the platform of the car is stiffer. Over the same slanted driveways with deep v shaped swails I can feel the car stand on three wheels like with my GT3 which has a very stiff and flat platform. I am not familiar with the ER hollow bars, but the primary benefit of hollow bars is to decrease weight for the same spring rate, which may be a couple of lbs. The Eibach rear bar is also hollow. But the main difference with all aftermarket bars such as the ER and pretty much every other aftermarket front bar out there vs. the Eibachs, is that you need to drill out the front wheel wells with a 1+" hole and three smaller bolt holes each side to pass the bar through and fasten the mounts, such as on an early 70s 911, then cut off the end link loop on your A arms and weld a new U-tab kit in it's place for the drop links. Not everyone with a SC and 3.2 wants to do that especially to a stock original car as it's not reversible. It is the reason I hesitated to change the bars. But the new Eibach bars don't require any of this. It mounts using the same mounts your stock bars use, so no cutting, welding, or drilling. I would venture to say it's the only adjustable bar set in existence that does not need you to drill and weld to your chassis. Most of the aftermarket bars are a 22mm diameter bar, which although I never had the ER 22 bars, I used to have Weltmeister 22 bars in my other car which were essentially all the same design, and combined with 22mm f and 29mm r torsion bars. Photos of the car on track showed the car had a lot lean when cornering at the limit with street tires such as Dunlop Direzzas. One could argue that I should at that point be running larger torsions such as 23/31 or larger, and fine tune with small sway bars, but if one were to do that, ride quality on the street is not the primary consideration anymore. Since the car spent a lot of time on the track and autocrossing, on the recommendation of Rich Walton/JWE, what really made a huge difference was replacing the 22mm Weltmeister bars and installing Smart Racing 31mm front through the body bars, and their 27mm rear bar, what a lot of fast track prepped 911s run. The car was transformed and instantly 2 seconds faster per lap. I could flick the rear end of the car around 180 degrees around a cone at will with the snap of of the throttle and hole shot out. Cornering with r-comps or slicks the car pretty much stayed flat and I could easily control oversteer and understeer with the throttle. Going through slaloms I didn't have to wait for the car to take a set as you're flicking the car side to side. But the SR bars also require drilling through the front chassis to mount, and the 31/27s are like over 300-400% stiffer than the stock bars and for sure you can feel the car ride harder on rough roads when they are set stiff. Such stiff bars I wouldn't recommend for a street car, at least not the 31s/27s. So with that I feel the Eibach 24 front/25.5 hollow rear bars, combined with their adjustability at least similar to aftermarket 22 bars if not potentially a bit more stiffer, making a good complement to the stock torsions, or upsized torsions such as 22/29s for sport street setup, without altering the chassis in any way. |
Eibach has revised their sway bar design from the initial prototypes you saw in the previous pics for the 1974 and up 911s and further improved their adjustability. They debut this Saturday at Eibach's Porsche event at their headquarters in Corona, CA. I have not seen the final system but here is a teaser pick of the linkages for the front sway bars which will be two way adjustable. The red bushing is Delrin and the monoball hemi joints allows for dialing out of any suspension preload: </br></br> http://forums.pelicanparts.com/uploa...1507693614.JPG </br> http://forums.pelicanparts.com/uploa...1507693614.JPG </br> http://forums.pelicanparts.com/uploa...1507693614.jpg
Went to Eibachtoberfest and picked up a rear bar to go with my Eibach coilovers. They we're practically giving them away with their show discount.
Eibachtoberfest 2017 My car is the #50 rag top pictured. Will install them this week and let you know my thoughts. Interestingly enough I also got a set of prototype backers made of machine aluminum instead of the stamped steel production bits. |
| All times are GMT -8. The time now is 07:17 AM. |
