Ferrino's Avatar
Pic Request - Footwell
I'm looking for some photos of stripped tubs in the area of the passenger footwell, please. My '76 911 had the "evaporator hole butchery" applied to it back in the day, in a similar fashion to this, albeit with a tin opener (I heard dealers used to cut these holes with an air-chisel!!!):
I need to patch this area up, but it's not just a simple flat piece of metal - there appears to be some curvature to it. Would be great to see pics of a virgin, naked tub. Thanks!
Old 09-20-2017, 11:29 AM
I used a flat piece of metal because the metal there was real wavy. It was essentially flat except for the hole for the blower resistor pack and the detail spot welded above my plate. Sorry I don't have a completely naked shot. I used it as a doubler for the battery box inside the smuggler's box area:
Old 09-20-2017, 01:26 PM
Ferrino's Avatar
Thanks for the pic. My cutout is much more expansive than your patch piece - it goes north and east of that.
Old 09-20-2017, 02:52 PM
Ferrino's Avatar
Bump
Old 09-21-2017, 02:29 PM
I had the same issue with my 73 Targa. I cleaned up the metal edge around the hole and took it to a body shop. They made up an exact patch piece and butt welded it in. They cleaned up the weld, primed seam sealed and painted black for $100. I then replaced the the sound deadner. Looks like it never was butchered. Rob
Old 09-21-2017, 06:23 PM
Send a message via AIM to fintstone
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 09-21-2017, 09:37 PM
D@vid's Avatar
Hi Ferrino,
I found the same butchery in my car. Maybe these pic's will help you.
good luck!
Kind regards,
1973 2.4 MFI
bone-stock 911T
Old 09-22-2017, 01:51 AM
Ferrino's Avatar
Thanks all. D@vid - yours is much like the cutout in mine - much appreciated!
Old 09-24-2017, 09:33 PM
Eng-o-neer
Tremelune's Avatar
If you can't find anyone to weld it for $100, another option would be to use Kydex to cover it up, attached by rivets or rivnuts (if you want it to be removable). Kydex is the brand name of a particular plastic polymer that is moldable with a heatgun, but otherwise rigid. I think ABS/HDPE/PVC sheets might also behave in a similar manner at 1/16".
Old 09-25-2017, 05:43 AM
911tracker85's Avatar
what would be the purpose of those cut outs?
Bob Cox
78 930 clone project car.
87 924S resurrect at some point.
84 928S, Ruby Red linen/brown interior - sold
86 944 turbo my new DE/track car - sold
Old 09-25-2017, 05:56 AM
Eng-o-neer
Tremelune's Avatar
On my '84 (and probably any with an AC compressor in the smuggler's box) there are numerous HVAC wires coming through there.
Old 09-25-2017, 06:55 AM
