-   -   3.2 engine modification? (http://forums.pelicanparts.com/porsche-911-technical-forum/971217-3-2-engine-modification.html)
Trakrat 09-22-2017 12:47 PM
Since I'm getting ready to remove my engine and start the process of a rebuild on my own...
I'm curious what you all recommend on upgrading?
I would like to keep it as a 3.2... but I would like to improve the internals and make the engine stronger than a stock 3.2. (after I cut my teeth with this car, I'll look at doing a monster build on a 964)
Any recommendation on what I should be looking at?
Any recommendation on a shop I should talk to?
I've reached out to Steve @ Rennsport Systems, but he's likely busy and slow to respond.
I've reached out to Competition Engineering, but never got a callback/response.
Raceboy 09-22-2017 01:17 PM
You could go with cams, exhaust, ITB's and get plug and play standalone ECU from here: www.facebook.com/vemsporsche. Works with factory sensors.
http://forums.pelicanparts.com/uploa...1506111432.jpg
gtc 09-22-2017 01:20 PM
Head studs. Rod bolts.
Everything else on a 3.2 is pretty strong.
darrin 09-22-2017 01:43 PM
While I recognize your intent to keep it as a 3.2, still think you should consider getting the cylinders bored to accept 3.4l "max moritz" pitsons and hottter (964?) cams -- along with gtc's suggestions of better rod bolts and head studs. This would leave you with a noticeable bump in power without adding too much more to your build. Sal carella is a good resource on this, as he's helped tune motroinc/chips on a few of these.
Trakrat 09-22-2017 02:18 PM
Already plan on getting Raceware for all replacements on the engine.
Trakrat 09-22-2017 02:25 PM
Thanks... but I'm not comfortable making permanent changes to the original engine.
911pcars 09-22-2017 06:14 PM
Huh? "Permanent" mods includes machining to accept parts not factory-equipped for that MY engine. Other than that, modifications to the basic engine don't have to be "permanent".
If mods are desired but aren't comfortable, then keep it ...... original. Did I misunderstand your objectives?
Sherwood
Trackrash 09-22-2017 06:36 PM
A good exhaust and a chip will really wake up a 3,2. 964 cams might be worth considering as well. Now if you need new cylinders.....
darrin 09-22-2017 07:39 PM
Sherwood
exactly -- not mods to case, you can keep your original pistons -- if you want 100% original, track down another set of cylinders and keep your p&c in the attic. If you're already tackling the top end and replacing rod bolts, you're already almost there labor/disassembly-wise.
Put back your original p&c and you're back to 100% original
AHudson 09-22-2017 08:07 PM
snipped:> Sal carella is a good resource on this, as he's helped tune motroinc/chips on a few of these.
I'm thinking you mean Sal Carceller, who is a remarkable jewel of a resource on these cars. The cams and pistons are a seriously great mod, but Sal makes a 'Chip + Injector' package that uses modern 4 hole injectors (a mist, not a stream for better, smoother combustion) and a chip that maximizes this combustion. Basically plug and play, totally reversible
I put this in my 3.2 with a Euro pre muffler and 'Sport' Dansk single outlet exhaust. These were not required by any means, but Sal will walk you through whatever other bits you're doing and help map the chip accordingly if needed.
He's really unreal. The chip + injector have made my car start quicker, pull harder, burn more evenly (I have an AFM installed permanently to monitor. The package is fantastically balanced.
Sal is conservative; he does NOT claim any more power than say, a Wong chip, only a more efficient chip/injector package with similar power. The entire package is about the same as some ask for chips alone. I give it a thumbs up.
JackMan 09-23-2017 04:26 AM
Keep the engine stock, rebuild the heads, put on SSIs and then change (lower ratios) the gears -- 2,3,5 -- of your G50 unit and install an LSD, put on adjustable koni's at each corner, reindex (lower) the car, install a wevo shifter, precision shift joint and wevo black pillow mounts for the engine and gearbox. Getting more power out of the engine costs way more than regearing the gearbox.
Cevan 09-23-2017 04:55 AM
I'd think twice on the SSIs for a 3.2 engine. Not sure how you can increase performance with a smaller primary ID (35mm) than your exhaust ports (38mm).
Trakrat 09-25-2017 07:08 AM
Sherwood
Exactly... boring out the engine to a larger displacement would be permanent.
I'm not sure what parts needs to be replaced or not yet... as I'm still working on getting the engine disassembled.
Unfortunately I'm having a difficult time finding a reputable Porsche machine shop that is willing to take my money to have my parts cleaned, machined, balanced, etc...
picinkoff 09-25-2017 07:57 AM
Try Ollies in AZ. They are well known and do a good job at a good price. I was happy with their work. They have a price list on their site.
Forgot to mention that it was for my '88 3.2.
Paul
Catorce 09-25-2017 08:01 AM
3.2 to 3.4 doesn't involve any boring. You buy another set of P and C and store your originals. Cylinders slip into case.
Trakrat 09-25-2017 09:01 AM
interesting... tell me more...
I'm guessing there is more to it than just dropping them in though... :confused:
Trakrat 09-25-2017 09:04 AM
Paul
You're the 3rd person to recommend them... definitely giving them a call!!! :D
darrin 09-25-2017 09:28 AM
not really, were you to increase displacement to 3.5, you need to machine the case to accept the bigger cylinders. However, bumping to 3.4 does not require any changes to the case -- it only requires boring the cylinders to accept bigger pistons (and buying bigger pistons). Only other mods would be a) more aggressive cams to take advantage of the additional displacement -- either re-grinding existing cams or buying a new set, and b) chip tuning to best take advantage of added displacement (both things you seem to be already contemplating)
Additional power can be found (through additional advance, etc.) if you were to also twinplug (which would require modification to the heads). However, this isn't necessary if you go with "Max Moritz" style pistons, which are optimized for single plug use.
Again, if you're concerned about reverting to complete originality, seek out a second set of cylinders to bore, hold onto your original cylinders and pistons and you can rebuild back down to your original 3.2 --
porschenut 09-25-2017 09:31 AM
Yep. SSI's were designed for 2.7 engines, but also work for 3.0. They aren't for 3.2 engines. However I think I read recently that someone is making stainless steel catless HE's with the 1 5/8" primaries necessary for the 3.2. It may have a been a thread here.
porschenut 09-25-2017 09:43 AM
Have you considered swapping in a 3.6 motor, preferably a vario from a 993 (approx 280 bhp)? Total cost including installation may be less than rebuilding the 3.2. And you can store the original engine.
