Member 911 Anonymous
DRACO A5OG's Avatar
Lightbulb FIX: Glove Box Latch Lever Return Spring with a ,68-79 VW part
So my 32 year old glove box lock finally gave up.
It no longer will spring back to latch to the hole to keep it closed unless I manually turn the latch.
A year ago, I tried to fix the broken lock lever return spring by placing a new catch point. Worked well but the tensile strength weakened over time and finally broke leaving no room to relocate the catch point.
Looking for a replacement LEVER RETURN SPRING was almost impossible due to the fact no lists the size (12.0MM OD) Hardware stores and even old school lock smiths just do not have the proper thickness or OD.
I started to contemplate just buying a new lock and swapping out the cylinder to keep the same key. $145??? Holy Fuch Batman
Then I happen to see the '68-79 VW lock, made by HELLA. It was identical to our 911 lock.
$13.50 for a knock off was cheap enough for me to take a chance.
BRAND NEW VW BUG BUS GHIA SUPER BEETLE PUSH BUTTON GLOVE BOX LATCH NON LOCKING | eBay
Received:
Happy to say the inner mechanism was the same. I chose the keyless one as I did not need the lockable one, only the two spings.
Voila, Fixed
'85 Carrera Targa
PCA/POC
Old 09-29-2017, 07:20 PM
Brew Master
cabmandone's Avatar
Timely! I have been complaining about my glove box latch not working for a while now. Now I'm gonna have to dig into it.
Old 09-29-2017, 07:26 PM
DRACO A5OG's Avatar
Thumbs up
Cool.
Just visualize the Lever Return Spring, you want it to compress as you turn right and spring back quickly. If you position it to unwind, the tension will not be enough.
Play with the position before knocking in the locking pin. I used a small needle nose to grab the pin. Be prepared the top latch spring will shoot out, go slow and in a clear place to search for parts if it springs apart on you :-)
Break a leg Brother!
'85 Carrera Targa
PCA/POC
Old 09-29-2017, 07:31 PM
HarryD's Avatar
Why not just install the VW lock assembly for everyday use and keep the original Porsche lock for the Concours Judges?
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 09-29-2017, 11:46 PM
DRACO A5OG's Avatar
Knob end is too short.
'85 Carrera Targa
PCA/POC
Old 09-30-2017, 12:30 AM
Tags
glove box lock
