Turn Signal Flash Rate
All four turn signals work but at twice the normal rate when signaling to turn but flash at a normal rate when using the hazard lights? Might this narrow it down to bulbs, relay, short? 86 Euro Carrera. Thanks.
Old 10-04-2017, 07:38 AM
Administrator
Dmitry at Pelican Parts's Avatar
If they didn't flash at normal rate when using the hazards, I would say that it's a bulb issue - try removing the bulb and cleaning the contacts and then re-installing, it may fix the problem. Other members should chime in as well for this one.
Old 10-04-2017, 10:21 AM
If someone replaced either front or rear set with LEDs, you get simiral results.
Old 10-04-2017, 10:28 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Turn signals.
Open turn signal bulb filament, or bad bulb to socket connection.
Clean as per host comment.
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 10-04-2017, 11:07 AM
Senior Member
Jdub's Avatar
Been through this. Ideally, all bulbs are not only from the same manufacturer, but the same manufacturing lot. Replace all bulbs, noting that you have solid grounds on the bulbs, and also on the chassis. When I did this I removed the entire light assembly and buttoned it all back up using bathroom caulk in lieu of the putty you will typically find.
'78 Targa in Minerva Blue
Old 10-04-2017, 11:36 AM
universeman's Avatar
If the relay isn't getting the right resistance, it will hyper flash. This could be
1. LEDs in one or more sockets
2. A bad ground
3. A bad bulb
Check the above and you should find your issue...
Jason - Austin, TX
82 911 SC targa (gone, but not forgotten)
92 968 coupe
Old 10-04-2017, 12:58 PM
Good call 76FJ55. The fronts are new with LEDS. I just don't understand why they flash normally with the hazard switch. Is there a easy fix to this short of replacing the units?
Old 10-04-2017, 01:04 PM
If you had originally said you replaced the bulbs with LEDs you would have got the answer sooner.
Either use LEDs with load resistors to simulate regular bulbs or replace the flasher with an LED capable unit.
Old 10-04-2017, 02:02 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Resistors maybe, but I am not an electrician.
How much resistance from a regular bulb, minus the resistance of the LED bulb, Solder that delta resistor in the front lines.
Just talking.
Some more "just talking". I bet the 4 way is blinking just a touch faster than normal.
I think the relays are a function of heat. Like a toaster, right?
What a resistor will do to LED lights, I don't know.
I do know they are cheap and a friend of a friend has used them to dummy down downstream O2 sensor results with decent success.
1981 911SC Targa
Old 10-04-2017, 02:19 PM
Bob Kontak's Avatar
Argh!!!! I thought I was Batman for a second. You beat me to it.
Good to hear confirmation. +1
1981 911SC Targa
Old 10-04-2017, 02:21 PM
The hazards flash all bulbs. They work because the flasher sees two regular bulbs as well as two LEDs. The LEDs alone don't draw enough current...almost like no bulb at all.
Simplest fix is to replace the flasher with one made for LEDs, doesn't depend on current, however it may not worn you about burnt out bulbs.
Old 10-04-2017, 02:40 PM
Thanks so much for the inputs. I'll look into the flasher.
Old 10-04-2017, 05:14 PM
