Tire size question
I have 225/50/16 in the back on 8J16.
Some say that 245 will work, is it really the case? Here is how the car looks now with 225.
1974 911 coupe 4 speed |
Bill V. I am sure will chime in but it may be close. That fitment is no problem for an SC. I will defer to Bill on your 76
Paul 2011 Cayman S | 1978 911 SC | 1975 914 | 1987 951 1995 993-Sold |1998 C2S-Sold | 2002 M3-Sold Instagram: @rennsport98 |
SC flares were installed on mine sometimes in the 80s.
245's will work if in SC spec....my 78 had troubles with the 205 up front 245 in back should have plenty...
That’s exactly what I want
Are your rims 8J16?
Under the radar
Yea, 245s fit.
I run 16x 9 in the back
Ok, thank you.
It sounds like 245 with 8j16 should be fine. Wish someone with the exact setup to confirm.
exactly. a must for 245s
SC needs camber -1° but 225 on 8s are just fine
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
The preferred wheel is a 9ET15 though BTW the J part just describes the wheel profile and is generally not important wrt the usual wheels we use. diameter, width and ET are what are important
No chance to get passed with 8x16 with 245s
for 245/45 x16 that is 7.5" to 9" for most of the lines I know of, TüV is it's own speciaal case
Is anyone running 225/55/16 on the rear tires of the SC ? 8" rim width.
I'm getting ready to replace my worn 225/50/16's and thought the increased sidewall height might be a better fit. thanks |
And honestly I'd only want it that way, as the wider tire just sits better on the wider rim. But hey, if you guys can pass a 245 on an 8", go ahead. Quote:
plus, what that does to drivefeel I can only guess.. more wobly? Just get new 225/50.
Please document your claim, otherwise it needs to be filed under more false news
Here is a recommendation from Porsche dated 3/16
https://www.porsche.com/usa/accessoriesandservices/classic/tyreapproval/
Paul 2011 Cayman S | 1978 911 SC | 1975 914 | 1987 951 1995 993-Sold |1998 C2S-Sold | 2002 M3-Sold Instagram: @rennsport98 Last edited by MARISOL78sc; 03-23-2018 at 06:53 AM.. Reason: new info |
This is what TüV relates to. there is the 9x16 listet with 245, the only combination of that sort (9x15 is not listet, but this passes TüV too). But no chance for 245s on 8x15/8x16. USA may handle this different.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit Last edited by Flojo; 03-23-2018 at 07:04 AM.. |
Those are just the tires that Porsche used when the cars were new, It says nothing at all about other wheel/tire combinations the only admonition is to use an N spec of the same make and type and speed index, This is pretty silly as tire availability is a very nebulous area, they come and go at the tire manufacturers whim For instance there is not a single tire type that was oe on say '86 Carrera that is now available. Sizes yes, updated N spec yes.
The ultimate authority is the tire manufacturers spec, Though I can certainly imagine local authorities insisting that only original equipment specs be used to pass local regulations. In the US not even the tire manufacturer's specs are looked at very carefully, I don't live in Canada but do believe that the situation there is the same as in the US
Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes | Last edited by Bill Verburg; 03-23-2018 at 07:51 AM.. |
1971 914-6 GT 3.6 1974 911 1976 911S leaf green backdate 3.2 |
