Dumb ? What is this part?
Small reservoir by the battery. It has fallen out and looks to be pretty corroded from the old battery.
1987 Targa |
windshield washer pump and/or headlight washer pump
68 Beetle 68 to 72 sold 72 911T Nov 71 to present P/U @ factory Nov 19. Car was gift to myself for surviving the army 67 VW split window 74 to 76 sold 81 VW caddy 81 to present |
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip |
Chain fence eating turbo
Water/meth injection pump!
Good for hot track days.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
Thanks!
Now I just have to figure out how to shove the rubber grommets back in their holes. Despite the corrosion, it still seems to work fine.
1987 Targa |
Fleabit peanut monkey
Windshield squirtie motor. +1 I don't have the headlight washer on my 81 but on a 944 I worked on the headlight washer was on the bottom of the fluid reservoir. It was way more robust than the windshield motor.
1981 911SC Targa |
Just did that recently.
I cleaned them then lubed them up with SilGlide a silicone lube then pushed and wiggled they went right in. jw
jwill911 Espresso brown metallic `87 Carrera Coupe (sold) Now living in Mississippi |
Schleprock
Pull the grommets out from the side of the washer pump bracket. Look closely and you'll see the bracket is slotted to allow the grommets to be inserted. Push the loose/free grommets into the chassis wall (the long end is used for pulling the grommet into place) and then reinstall the pump to the grommets by sliding the bracket slots into the grommets
Kevin L '86 Carrera "Larry" |
Looks corroded, these things wear out and are cheap to replace...
The trick on the grommets is carefully pry them sideways out of the pump bracket with a small screwdriver and don't pull them out of the front panel. The slots in the pump bracket are C shaped which makes it tough to get them back in place, so use a dremel or small disc cutter and make the slots U shaped. The grommets slip in easily and the pump ain't going nowhere.
The way the pump looks, I may assume it does not work anymore(?), so I'd not install it, as retreiving it when finding out its dead, it will rip the grommets.
If it does work, I'd refurbish/clean it (inside/outside) before reinstalling.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
thanks for asking. was trying to figure out what that was in my car also.
Jeremy Brooks AKA VWLOOSENUTS ***My cars are built to meet my approval, not yours!! My money, my cars, my happiness. |
