bobspace's Avatar
Porsche Crest Can't find elastic bolt for my 901. Can I use a different part?
I have a 1969 911T 5sp. with an elastic bolt with part no. 90133227511
I can't find new ones anywhere!
However, there is a different part, 90133227501, that is still available. The difference is that the '11 has a little nipple at the end and the '01 does not. Can I use the 01 in its place?
Photos for comparison:
Old 10-03-2017, 11:52 AM
The bolt with the nipple is used with the infamous simplified differential. They are prone to wear and cause catastrophic failure. You may save your trans by getting rid of the simplified diff parts and changing back to original style which uses the lower bolt without nipple. Use the search feature here. There are lots of threads on this subject.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 10-03-2017, 12:04 PM
NO. The nipple secures the cross-shaft in the spider gear assembly. Without it or if the nipples wears enough to break off, the shaft slides out and disaster occurs, to put it mildly.
206 637 4071
Old 10-03-2017, 12:13 PM
Google or bing the part number and several places come up that supposedly stock it.
206 637 4071
Old 10-03-2017, 12:17 PM
bobspace's Avatar
I've followed up with a couple of places that claim to stock it and they either can't actually get the part (but they keep in on their website) or it's a used part. My mechanic claims that this bolt is stretched during use, so I should find a new one, and also that the one currently in place can't be removed and reinserted.
Another important point: He hasn't removed the bolt yet, so there's a slim chance that it's the 01 part and not the 11 in the first place. Would there be a way to tell what it is without removing it (i.e. the design of the flange)?
Old 10-03-2017, 12:33 PM
They are reusable, so feel free to inspect it, but only do one at a time or the shaft can slide and you won't be able to get it back in properly.
206 637 4071
Old 10-03-2017, 03:00 PM
