Question Why so many clutch release levers?
Dear friends
I have this 1978SC and itīs missing the clutch release lever, then I was looking the part number to try to find this part and I notice from the PET file that there is many types of Levers!
Why is that? Whatīs the difference between one and the other?, can I use any one in the 915 tranny?
In this particular car the right lever is the #13 on the PET file, since my cable is the Hook one (930 423 401 05) and on the car I see the parts #22 and #23
What is strange to me is that my 1976 S have the #7 lever and my 1983 SC have the #7 lever as well (both with a cable with a 7mm thread end)
If by 1978 they change for this more complicated system, why by 1983 they came back to the old system
My point being is that, now that I need to buy one I would like to buy the cheapest one that works I figure #7 should be cheaper since is just one arm, may be wrong though...
So, can I? Use any lever? Or I have to stick with #13 system with the omega coils and etc?
Thank you all
Old 10-06-2017, 07:01 PM
The SC system was used between 77 and 86 with exception of 77 euro with the 150 horse used the 76 style arm.
The three long independent levers use a shorter vertical shaft.
On the 83, I would check the year of the box because it was either changed or massive work was done to change the vertical shaft and the cable.
Bruce
Old 10-07-2017, 02:47 AM
Hi Bruce,
Iīll try to located the original part with the omega spring, thanks!
Old 10-07-2017, 08:17 AM
