Smart Racing Anti-roll bar...
Just wonder if anyone has experience with these? Good / bad?
And anyone tried them on a 930? What size bars are you using?
thanks...
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 02-06-2003, 11:11 AM
I haven't yet, but I'm saving up the money for one for my 930.
Brian
Brian Keith Smith
Old 02-06-2003, 11:17 AM
Irrationally exuberant
ChrisBennet's Avatar
Do a search, I think they've been talked about. I think there may be an issue with ground clearance.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 02-06-2003, 11:25 AM
Administrator
Jack Olsen's Avatar
I'm putting a rear one in the new version of my car. 23mm. Haven't used it yet, though, so nothing to report other than that they have a great reputation and a smart design.
Old 02-06-2003, 11:54 AM
I have used them on a Turbo...Great bars and they look nice too
Old 02-06-2003, 02:58 PM
APKhaos's Avatar
Great bar. Sensible, simple design, ultra strong yet light [not the bar itself!], very well made, simple to set up and easy to adjust. Yes, the trailing arms do reduce ground clearance a bit, but thats a non-issue unless you are planning on using the local car wash on a regular basis.
The bars are interchangeable if you ever want to move up/down, or move it to another car.
Tony K
'89 944T
944 SuperCup Champ 2004 & 2005
'85 Carrera - Sold [sob]
TrackVision
944Cup
The 999 Site
Old 02-06-2003, 04:32 PM
After two years use, they have held up well. A few thoughts; they are very durable and will focus any weakness of you sway bar setup onto your mounting points of your car. Make sure your mounting points are reinforced, the fronts with additional sheetmetal welded to the inner fenderwall and the rear sway bar mounts gusseted and reinforced. They fit also is almost too precise. I had some trouble in getting the bar to fit into the mounts without binding. The fit is precise. I went with 27mm front and rear.
Old 02-06-2003, 08:50 PM
PRO Motorsports
Tyson Schmidt's Avatar
In my opinion, these are the standard by which all others are measured.
The geometry is excellent. They are at least half the weight of other bars. They are durable. They are beautiful. And as 89911 says, they are very precise.
Worth every penny. And they cost a LOT of pennies!
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 02-06-2003, 09:12 PM
jphillips-998's Avatar
HIGHLY RECOMMENDED! Went through AJ USA bars and broke the drop links on the second track day.
SRP bars are very easy to adjust, look great and have held up like no others.
Jeff
'04 Cayenne S Hauler
'98 993 Cab
'74 Euro Carrera - SOLD
'91 944S2 Track Car
Old 02-06-2003, 10:46 PM
Limbo
Slider79SC's Avatar
For a little less money you could go with the Racers Group bars. I have had nothing but excellent results with mine. Easy to adjust, install and fit was perfect. I think I got mine for $900 for the pair straight from the Racers Group.
Big ol built Duramax
Durango R/T 19’ Current Custom project
V8 M3 08’ Built and spoiled
Old 02-07-2003, 06:24 AM
