Going around in circles with 16x7 RE11 tire sizes
There are lots of posts lots of info but few combinations of like brands that work.
I have 16x7 and 16x8 fuchs. I have already decided on 245/45/16 RE11s for the rear. I have rolled fenders and bilsteins and from what I can tell good bushings. Should I go with 205/45/16 205/55/16 or 225/45/16 or 205/50/16 for the front if I am buying RE11for the front as well. Bridgestone has a $70 rebate if you buy 4 today btw. Thanks! Ryan |
Can't recommend 245 on an 8. I have 205 on my 7s, 225 on my 8s and 245 on my 9s.
Sent from my Nexus 6P using Tapatalk |
245s bulge terribly on an 8. If you're drag racing, it is OK. For cornering, not so much.
Thanks for the quick responses!
So 7-8mm spacers and 225 50 or 45 for the rear then? 205/55 50 or 45 for the front? |
I assume that ultimate grip isn't the main priority else RE71R would be your choice. So 245/45 though better on a 9 is ok on an 8. section width on a 9 is ~10"(254mm) on an 8 it is ~9.6"(244mm). Tread width of course stays the same and there is a very minor change in OD, not enough to worry about. You'd get a bit more grip from this tire on a 9 than on an 8. I don't believe that R 11 is available in a 205/50x16 or 225/45 x16size Matching front on a 7 could be 205/45 or 205/55. Each has + & - /45: avoids and clearance issue due to shortness but optics are a bit odd due to the same shortness OD is ~23.2" compared top 245 OD of 24.7" /55: @ 24.9" OD a good match for 245's 24.7" OD, On lowered cars there can sometimes be some lip interference but it's not likely for most especially w/ rolled fenders and more stockish ride height. You'll get about the same grip from either version 205 225/50 could fit on the 7s but there is a far greater likely hood of interference |
i run 225 and 245 RE11's on 7&8x16's on my 914. they are wide, but don't bulge terribly. handling is lights out, but that car is really set up and obviously not a 911.
pics for reference... http://forums.pelicanparts.com/uploa...1507502892.jpg http://forums.pelicanparts.com/uploa...1507502935.jpg http://forums.pelicanparts.com/uploa...1507503052.jpg |
for your fronts go with 205/55 16, like the factory did
245s on 8s look much better than I expected. I do prefer the 205 fronts for lighter steering.
I did not even consider the 71Rs since they did not come in the 245 and I wanted the "big ass/RSR" look for the rears. The Re71 don't come in a 245 so these would have to be a 205/55 or 205/50 and 225/50 for the rears. For $500 shipped after rebate they do make a compelling case for value/grip even if they don't give me the look I was going for on Magnus's SC Stance Works - Magnus Walkers 78SCHR Budget Porsche 911SC Build I'm aware he probably had camber plates. Thank you everyone for your input. I guess I'll pull the trigger once I know which fronts will go better on the car if I lower it to euro ride height. |
225/50 x16 RE71 on an 8 has ~9.6" section width, 7.6" tread width, this is the max wheel width and results in the max performance of an outstandingly good tire 245/45 x16 RE11 on an 8 has ~9.6" section width, 9.1" tread width, the max wheel here is 9 which measures ~10" s/w & the same 9.1" t/w. Still a very good street tire but it just wont have the performance potential of the smaller 71 |
Ended up buying a set of RE71R 225/50 and 205/55 at simpletire.com After rebate they came to $471. Not bad. should I run a spacer in the back to fill the fender a bit better?
-Ryan |
I suggest you start without spacers and see what you think -- super easy to add spacers later |
The RE11 are wider than the size suggests. This may be because they are somewhat "square" at the edges and not rounder like some other models. Because of this I would recommend the 205/55 at the front and 225 at the back
| All times are GMT -8. The time now is 11:06 PM. |
