Going around in circles with 16x7 RE11 tire sizes
There are lots of posts lots of info but few combinations of like brands that work.
I have 16x7 and 16x8 fuchs. I have already decided on 245/45/16 RE11s for the rear.
I have rolled fenders and bilsteins and from what I can tell good bushings.
Should I go with 205/45/16 205/55/16 or 225/45/16 or 205/50/16 for the front if I am buying RE11for the front as well.
Bridgestone has a $70 rebate if you buy 4 today btw.
Thanks!
Ryan
1977 911S 3.2l hotrod with BarryWhite exhaust. 1974 911 with RS flares and Sport Seats 2001 996TT 6MT 1972 BMW M2 1971 DeTomaso Pantera (Boss/351C HO) 2007 Touareg V10 TDI No kids -no wife - obviously
Old 10-08-2017, 11:16 AM
3 restos WIP = psycho
kenikh's Avatar
Can't recommend 245 on an 8. I have 205 on my 7s, 225 on my 8s and 245 on my 9s.
Sent from my Nexus 6P using Tapatalk
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 10-08-2017, 11:17 AM
kjchristopher's Avatar
Agreed. If you’re going for performance, that’s too much tire in most cases. The 205/225 plan is a better one.
Old 10-08-2017, 11:24 AM
Slippery Slope Victim
NY65912's Avatar
What he said
Mike²
1985 M491
Old 10-08-2017, 11:27 AM
kenikh's Avatar
245s bulge terribly on an 8. If you're drag racing, it is OK. For cornering, not so much.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 10-08-2017, 11:37 AM
Thanks for the quick responses!
So 7-8mm spacers and 225 50 or 45 for the rear then? 205/55 50 or 45 for the front?
Old 10-08-2017, 11:58 AM
needspeed's Avatar
I have 225/50 on my 16x8s.
Old 10-08-2017, 12:11 PM
Bill Verburg's Avatar
Thanks!
Ryan
depends on what you are looking for
I assume that ultimate grip isn't the main priority else RE71R would be your choice.
So 245/45 though better on a 9 is ok on an 8. section width on a 9 is ~10"(254mm) on an 8 it is ~9.6"(244mm). Tread width of course stays the same and there is a very minor change in OD, not enough to worry about. You'd get a bit more grip from this tire on a 9 than on an 8.
I don't believe that R 11 is available in a 205/50x16 or 225/45 x16size
Matching front on a 7 could be 205/45 or 205/55. Each has + & -
/45: avoids and clearance issue due to shortness but optics are a bit odd due to the same shortness OD is ~23.2" compared top 245 OD of 24.7"
/55: @ 24.9" OD a good match for 245's 24.7" OD, On lowered cars there can sometimes be some lip interference but it's not likely for most especially w/ rolled fenders and more stockish ride height.
You'll get about the same grip from either version 205
225/50 could fit on the 7s but there is a far greater likely hood of interference
Bill Verburg
Old 10-08-2017, 01:30 PM
i run 225 and 245 RE11's on 7&8x16's on my 914. they are wide, but don't bulge terribly. handling is lights out, but that car is really set up and obviously not a 911.
pics for reference...
Old 10-08-2017, 03:52 PM
Checked out
McLovin's Avatar
for your fronts go with 205/55 16, like the factory did
Old 10-08-2017, 04:19 PM
kenikh's Avatar
245s on 8s look much better than I expected. I do prefer the 205 fronts for lighter steering.
- 1969 911S
- 1980 911SC Targa
- 1979 930
Old 10-08-2017, 05:24 PM
I did not even consider the 71Rs since they did not come in the 245 and I wanted the "big ass/RSR" look for the rears. The Re71 don't come in a 245 so these would have to be a 205/55 or 205/50 and 225/50 for the rears. For $500 shipped after rebate they do make a compelling case for value/grip even if they don't give me the look I was going for on Magnus's SC Stance Works - Magnus Walkers 78SCHR Budget Porsche 911SC Build
I'm aware he probably had camber plates. Thank you everyone for your input. I guess I'll pull the trigger once I know which fronts will go better on the car if I lower it to euro ride height.
Old 10-08-2017, 05:38 PM
You have to remember that the wheel width affects the mounted tire section
225/50 x16 RE71 on an 8 has ~9.6" section width, 7.6" tread width, this is the max wheel width and results in the max performance of an outstandingly good tire
245/45 x16 RE11 on an 8 has ~9.6" section width, 9.1" tread width, the max wheel here is 9 which measures ~10" s/w & the same 9.1" t/w. Still a very good street tire but it just wont have the performance potential of the smaller 71
Bill Verburg
Old 10-09-2017, 08:21 AM
Ended up buying a set of RE71R 225/50 and 205/55 at simpletire.com After rebate they came to $471. Not bad. should I run a spacer in the back to fill the fender a bit better?
Old 10-09-2017, 08:23 AM
That's up to you, It does increase rear grip a bit which increases understeer, most do it for the optics
Bill Verburg
Old 10-09-2017, 08:28 AM
I'm after a bit of both for now. (New and first time 911 owner)
-Ryan
Old 10-09-2017, 05:57 PM
Speed Metal Army General
I run the exact same combo. Good stuff on 7&8s
Old 10-09-2017, 09:56 PM
I'm quite happy with the visual improvement I realized when I switched from 16x7 to 16x8 rear fuchs (running 225/50-16 tires on both).
I suggest you start without spacers and see what you think -- super easy to add spacers later
Old 10-10-2017, 11:17 AM
Thanks Darrin!
Old 10-10-2017, 11:22 AM
The RE11 are wider than the size suggests. This may be because they are somewhat "square" at the edges and not rounder like some other models. Because of this I would recommend the 205/55 at the front and 225 at the back
"With an stock-original car, you serve the car. With a hot-rodded car, the car serves you."
Old 10-10-2017, 12:10 PM
