3.2 engine modification?
Since I'm getting ready to remove my engine and start the process of a rebuild on my own...
I'm curious what you all recommend on upgrading? I would like to keep it as a 3.2... but I would like to improve the internals and make the engine stronger than a stock 3.2. (after I cut my teeth with this car, I'll look at doing a monster build on a 964) Any recommendation on what I should be looking at? Any recommendation on a shop I should talk to? I've reached out to Steve @ Rennsport Systems, but he's likely busy and slow to respond. I've reached out to Competition Engineering, but never got a callback/response.
1987 Porsche 911 Carrera Coupe |
Turbonut
You could go with cams, exhaust, ITB's and get plug and play standalone ECU from here: www.facebook.com/vemsporsche. Works with factory sensors.
'83 924 (2.6 16v Turbo, 530hp),'67 911 hot-rod /2.4S, '78 924 Carrera GT project (2.0 turbo 340 hp), '84 928 S 4.7 Euro (VEMS PnP, 332 HP), '90 944 S2 Cabriolet http://www.facebook.com/vemsporsche |
abides.
Head studs. Rod bolts.
Everything else on a 3.2 is pretty strong.
Graham 1984 Carrera Targa |
While I recognize your intent to keep it as a 3.2, still think you should consider getting the cylinders bored to accept 3.4l "max moritz" pitsons and hottter (964?) cams -- along with gtc's suggestions of better rod bolts and head studs. This would leave you with a noticeable bump in power without adding too much more to your build. Sal carella is a good resource on this, as he's helped tune motroinc/chips on a few of these.
Already plan on getting Raceware for all replacements on the engine.
If mods are desired but aren't comfortable, then keep it ...... original. Did I misunderstand your objectives? Sherwood |
Under the radar
A good exhaust and a chip will really wake up a 3,2. 964 cams might be worth considering as well. Now if you need new cylinders.....
Put back your original p&c and you're back to 100% original |
I put this in my 3.2 with a Euro pre muffler and 'Sport' Dansk single outlet exhaust. These were not required by any means, but Sal will walk you through whatever other bits you're doing and help map the chip accordingly if needed. He's really unreal. The chip + injector have made my car start quicker, pull harder, burn more evenly (I have an AFM installed permanently to monitor. The package is fantastically balanced. Sal is conservative; he does NOT claim any more power than say, a Wong chip, only a more efficient chip/injector package with similar power. The entire package is about the same as some ask for chips alone. I give it a thumbs up.
Porsche M491 Coupe '85 Porsche 997 GTS '12 Porsche 911 SC, '82 Porsche 914-6, '70 Audi S4 Avant V8 manual, '05 Last edited by AHudson; 09-22-2017 at 08:10 PM.. |
AirBorne!
Keep the engine stock, rebuild the heads, put on SSIs and then change (lower ratios) the gears -- 2,3,5 -- of your G50 unit and install an LSD, put on adjustable koni's at each corner, reindex (lower) the car, install a wevo shifter, precision shift joint and wevo black pillow mounts for the engine and gearbox. Getting more power out of the engine costs way more than regearing the gearbox.
2008 997 C4S Silver, Kitty Cat, 1989 3.4 911 Silver Carrera, Erica, 1989 944S2 NASA GTS2, Iris, 1988 944 DE Car, Backdate 1975S to 1970s w 3.0 PMO - Roxanne, 1967 911 normal w 2.2s engine w S goodies, 89 VW Cabriolet - 2.0 conversion - sold and missed |
1986 Carrera coupe - black on black 1972 CB500/4 |
I'm not sure what parts needs to be replaced or not yet... as I'm still working on getting the engine disassembled. Unfortunately I'm having a difficult time finding a reputable Porsche machine shop that is willing to take my money to have my parts cleaned, machined, balanced, etc...
Try Ollies in AZ. They are well known and do a good job at a good price. I was happy with their work. They have a price list on their site. Forgot to mention that it was for my '88 3.2. Paul Last edited by picinkoff; 09-25-2017 at 08:19 AM.. |
I'm guessing there is more to it than just dropping them in though...
Additional power can be found (through additional advance, etc.) if you were to also twinplug (which would require modification to the heads). However, this isn't necessary if you go with "Max Moritz" style pistons, which are optimized for single plug use. Again, if you're concerned about reverting to complete originality, seek out a second set of cylinders to bore, hold onto your original cylinders and pistons and you can rebuild back down to your original 3.2 -- |
Recreational User
Yep. SSI's were designed for 2.7 engines, but also work for 3.0. They aren't for 3.2 engines. However I think I read recently that someone is making stainless steel catless HE's with the 1 5/8" primaries necessary for the 3.2. It may have a been a thread here.
Recreational User
Have you considered swapping in a 3.6 motor, preferably a vario from a 993 (approx 280 bhp)? Total cost including installation may be less than rebuilding the 3.2. And you can store the original engine.
