Rennshift or Porsche factory short shift
Hey guys,
Looking to change to a reduced throw and add a bit of protection against the dreaded money shift.......ive narrowed it down to two options the Rennshift and the factory short shift kit and was curious to hear from the group pros and cons or preferences for these two options. I would likely add the seine gate shift option for the Porsche factory short shift kit if I go that route. Thoughts....all opinions welcome and appreciated. |
No wevo?
Sent from my Pixel using Tapatalk |
3 restos WIP = psycho
I love the Rennshifter
Sent from my iPhone using Tapatalk Pro
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
Racer
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
Reiver
Does the factory short shift kit pre load (spring elements) both sides of the shifting plane so the shifter naturally seeks center?
I honestly do not know but if it does not then you are more inclined to make a money shift. I tried the adding springs to the stock unit (commercially sold) and it was nicer than stock but the Rennshift unit is truly excellent.....you would have to 'work' to make a money shift and the unit is beautifully made and easy to adjust (change sprig ratios to suit your personal feel). Very pleased with the unit. Assuming you have a 915 tranny one still must adapt to it's internals but this makes it a much more pleasing experience.
De Oppresso Liber Strength and Honor 5th Legion |
I've heard great things about the Wevo and read many threads but honestly the price point is a bit too high for me for what you get. I like the idea of keeping everything porsche with the FSS kit but also have driven the Rennshift and was very impressed by the feel. I'm not dead set against Wevo if people feel it's superior to the Rennshift and FSS kit with seine gate set-up.
Shift kit.........
I have the factory short shift kit in my SC. Seems to work quite well and made a significant reduction in shift length. It is spring loaded to center.
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
911SC Tinkerer
Dynosaor,
I've driven a stock shifter, a factory short shifter, and my own stock throw with seine gate shift. If I had it to do over again I would get the Rennshift, refresh all the bushings in the shift mechanism and rebuild the coupler. The Rennshift is the most complete new parts solution and just looks great naked. As far as the seine is concerned, it's wonderful if not a little bulky on the outside. That form of gate shifter has been around for quite a while. Robotek made one before seine as far as my research showed. My rubber boot covers the mechanism completely and I've had no problems with ripping. I also slightly modified the seine with tighter tolerance springs and "blueprinted" the shifter by sanding and tightening the inside bits. I would avoid the short shifter. It just made things too tight and (for me) always felt the transmission syncros were under more stress. Maybe just my imagination. There's not much you can do to improve the ergonomics in the early cars so improving the shifter does pay huge dividends. As always, try different stuff to see what works for you. We are all different in our approach to perfection here. -Steve
-'83 911SC Coupe SSIs, Dansk GT3, EFI ITB, Instagram: @ Zinnmetallic_sc |
Bland
You know that the Porsche 901, 911, 915, and 930 transaxle are slow shifting units? This is why they were designed with such a long throw.
If you put in a short shifter, you really can't shift any faster. These will never shift like a Toyota.
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
Under the radar
I have the factory short shifter. Not the kit, but the shifter used in the last of the Carreras, before the G50.
I added the Seine gate kit. It is solid and precise. Spring loaded to the 3-4 plane. Does anyone know if the factory short shift kit will make the old 915 shifter the same as the newer 915 short shifter? I have heard conflicting accounts on this and that the newer 915 shifter is different and superior to the factory kit. Is this true?
When it comes to the 915, the one thing that I can say without a doubt is that the number one best upgrade you can do to a 915 is add the Wevo gate shift kit, the one that is internal to the transmission. It makes the transmission feel like a G50. Worth every penny. And that is with the stock long throw shifter.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 Last edited by kenikh; 10-15-2017 at 08:39 AM.. |
Reiver
The Rennshift does not detract from that and enhances it with positive selection within the parameters of the 915 personality....dog teeth and all
![]() Sherwood |
Under the radar
Reiver
You are indeed correct. The short shifter does not add any self centering
feature as was indicated earlier in this thread. All the kit does is shorten the stroke!
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
I also have the Seine gated shifter installed in my 915. I have the polished and "blueprinted" complete unit that Sherwood @ Seine offers. In addition I added the factory short shift kit, BUT I also added a 6" extension to the shift stick. The longer stick puts the shift knob right where my hand falls on it and feels more ergonomically correct to me. The longer stick also negates the short shifter problem you mentioned of a "too quick shift" due to the change in geometry and longer throw. It now shifts just like an original shifter without a SS kit. Sherwood has now offered the shift extensions for sale and indeed uses one himself. John Walker at one time showed one he made for himself. The nice part of the longer stick is you no longer "reach" down to the shifter. My setup shifts like buttah and is one of the best improvments I have ever made to my car.
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa Last edited by uwanna; 10-15-2017 at 07:36 PM.. |
Reiver
Does this really speed up shifting or simply give the impression of that?
