Idle Help ASAP
Started car for 1st time in 3 months. Want to adjust idle but can't find the jumper diagram before adjusting idle screw. Can someone help?
JG
1985.5 944 GTS |
DME does not need adjustment. That said, you can still do it by removing the yellow cap (1/2" size) covering the idle screw and go at it. You will need some kind of CO meter to really make it accurate. Best leave it alone, or send it to a smog station for adjustment.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
one of gods prototypes
what's the idle problem you're having that you want to adjust?
Brought to you by Carl's Jr. |
Seems a little low. I meant to do it last fall but never did.
JG
1985.5 944 GTS |
have you checked your plugs? i had a similar problem last year.....installed new plugs and it idled perfectly again.
my .02
