81 SC instrument bezel help
Im trying to figure out how to take the rings off the instrument clusters. they have some age on them and would like to sand them down and re-paint them. but im stuck on how to take the bezles off, do you turn them left or right or pry them out from the housing?
thanks
06 E55 600HP
08 Clk63 black series 590HP
81 SC targa 3.0
91 E34 M5
Old 10-18-2017, 03:19 AM
cpa cpa is online now
thanks
Search for threads on repairing inoperative odometer. There are many good explanations on removing the bezel. You have to carefully pry them off from the back edge.
Old 10-18-2017, 05:03 AM
There is some information on this here:
http://www.pelicanparts.com/techarticles/101_Projects_Porsche_911/89-Odometer_Repair/89-Odometer_Repair.htm
1981 911SC
Old 10-18-2017, 06:34 AM
echecsqueen's Avatar
The first one I tried was really hard but once you see how it is put togther it will make more sense.
Tips... Use a very narrow screw driver and pick a spot. Lever the tip under the back of the bezel where the black meets the silver and turn your screw driver a bit to create a burr or edge. Then working in either direction start prying the black bezel away from the silver part. At first you will think you are doing something wrong and making no headway. The metal will look a little kajangled. After several times all the way around, the bezel can be slipped off. The c shape of the back of the bezel is now straight. After you are done when you put it back together the rear will look a little ragged. I haven't figured out how to re-cup the area so it is smooth...but doesn't show.
Wear heavy gloves, sharp work.
1988 911 Coupe Granite Green "Frogger"
1966 912R Coupe Stone Grey outlaw -"'Tilda"
1978 924 White with Cork (Streetcar vs. Porsche - streetcar won)"Poindexter"
1984 924s Nile Green Metallic with bone (totaled it in the snow in Cleveland, Ohio)
1983 911 White with Cherry Red...gave away (not enough time or money to keep it running) in 2001
Old 10-18-2017, 01:52 PM
thank you all for the response. sorry for the late reply so busy at work.
06 E55 600HP
81 SC targa 3.0
91 E34 M5
Old 11-15-2017, 07:48 AM
