Russ
Engine not cooling
Hello guys,
I'll start this by saying i noticed the engine not cooling after I changed oil from the winter mix( 15-40) to the summer mix (20-50). I use Brad Penn oil.
I have checked to make sure all the cooling tin is in place and all the other cooling pieces. I've even cleaned the oil cooler and checked the voltage at the fan located on the oil cooler.
Do you think there is something odd with the oil?
Today the weather was really nice, ~84F and engine temp was ~250F and climbing when I got home from work, which is a 20min ride.
Amy advice is greatly appreciated.
Thanks,
Russell
Old 09-08-2017, 02:07 PM
Have you checked to see if your external thermostat is working as it should?
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 09-08-2017, 02:12 PM
universeman's Avatar
This is new? I don't think an oil change could cause overheating...are you sure you put in enough oil (check level again?) Is your oil cooler up front getting hot?
Jason - Austin, TX
82 911 SC targa (gone, but not forgotten)
92 968 coupe
Old 09-08-2017, 02:16 PM
Cars and Cappuccino
tdw28210's Avatar
Did an oil LINE get crushed during the change?
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 09-08-2017, 02:18 PM
As you know, 250 deg F is FAR too hot so this problem needs to be addressed before you drive it again.
I would start by removing the external thermostat to check and make sure its opening all the way by 190 degrees. You can remove the element and test it with boiling water and a thermometer to see when its all the way open.
After that, check the CO & ignition timing.
Check the cat to make sure its not clogged or obstructed in any way (not uncommon).
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-08-2017, 02:46 PM
Russ
Engine Not Cooling
Hey guys,
Thanks for the quick replies and suggestions. It is too nice out not to drive...
That is a good thought about the thermostat. I assumed it was working because the oil cooler is hot. I will check to make sure it is operating correctly.
The oil level is good. I check it regularly and it is generally pretty close to full.
tdw28210, I don't understand your statement.
Thanks,
Russell
Old 09-08-2017, 02:47 PM
Russ
Steve,
Thanks for your help. I'll pull the thermostat and see what happens. Forgive my ignorance. What is CO?
I guess it is possible that the timing could have advanced. I will give that a check too.
Thanks!
Old 09-08-2017, 02:51 PM
Cars and Cappuccino
tdw28210's Avatar
Originally Posted by Turpin View Post
Hey guys,
Thanks,
Russell
Turpin,
I was wondering if somehow one of the oil tubes that runs along the outside edge of the tub got crushed somehow during the oil change process. A misplaced jack, lift arm or even jack stand could do it.
Old 09-08-2017, 03:32 PM
pavegeno's Avatar
Send a message via Skype™ to pavegeno
Mine ran hot and it was the engine mounted cooler. Assumed it was the external thermostat or FR wheel cooler but it was the engine mounted all along.
2002 GMC Yukon SLE - 4AT - Purchased New in 2002
1988 911 Cab - 5MT - Purchased Used in 2005
2008 Cayman - 5MT - Purchased New in 2007
2014 911/50 - #1173 - 7MT - Purchased CPO in 2014
2019 Macan S - 7PDK - Euro Delivery/New in July 2019
Old 09-08-2017, 03:56 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Pm
PM sent.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 09-08-2017, 04:41 PM
vansicklenmi's Avatar
Check the coolant level
'75 Carrera, It's stock, I swear, scouts honor!
Old 09-08-2017, 08:02 PM
Steve,
Thanks!
My pleasure.
CO is Carbon Monoxide and one major parameter for setting fuel mixture (using a 4- or 5-gas analyzer). Make sure its set at factory timing, both at idle and 6K RPM.
Good luck!!
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 09-08-2017, 10:27 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
Another thing to check, which I don't think has been mentioned, is to look in through the engine fan the best you can (with flashlight, small mirror, etc) to see if rodents have packed the tops of the cylinders and heads with food and nesting material . . . very common and I've even seen pics from a member where mice had covered the entire top of both banks with large, horse treat pellets.
Old 09-09-2017, 12:09 AM
Russ
Hello guys,
I pulled the alternator and checked for rodent nests. I didn't find any nests but I did notice some gaps where the air moves into the heater hoses.
I also found out that my alternator diodes are bad.:-( So I'll a little more time to investigate the cooling issue.
I will order a CO tester. I could use one for my 59 VW KOMBI too.
Thanks,
Russell
Old 09-09-2017, 02:31 PM
Russ
here is an update on the situations...
Turns out that the alternator is good. It was the starter causing the battery drain. Installed another starter and the battery drain went away. :-)
I did pull the oil thermostat and submersed it into some boiling water. It appeared to be working fine. I did happen to notice that the thermostat was installed incorrectly. I guess when I installed ~4years ago I connected the oil lines to wrong in & outs????
So I am guessing that the thicker oil couldn't flow as easily as the thinner oil. Plus the thicker oil carries more heat. I still have 20-50 oil in the car. I will probably change to 15-40 in a couple of months.
Everything appeared to be good on the 20min test drive.
Thank guys!
Old 09-17-2017, 05:05 AM
Russ
Okay guys,
Here is an update on the "engine running warmer than normal" isssue. I changed the oil back to 10-40 and bam! Engine temp stays between 180&210 with normal driving.
It is very bazaar that the oil was causing the engine to run warm. It makes me wonder if something was wrong with the oil???
Anyway, anther data point
Thanks for all your suggestions and help!
Old 10-21-2017, 06:21 PM
Reiver
Reiver's Avatar
Okay guys,
A 50-60 degree difference in oil temp I'd think is unusual if all things are equal....I wonder if you have some kind of restriction in your oil cooling system. A restricted oil tube, backwards sump plate...
BP 20-50 is a high viscosity....I believe it 'thicker' than say VR1 20-50 under load...but I see no real difference in temps due to that.
I just used a case of BP as I had it...altho I have been using VR1...and today ran at 185 because it was cooler this morning in the Phx, Az.it maxed at 195.
I suspect you have some other issue with that large a spread.
Do your oil pressure rredinsg remain the same with both oils...or close?
De Oppresso Liber
Strength and Honor 5th Legion
Old 10-21-2017, 06:29 PM
Russ
The 20-50 was Brad Penn. I'm not sure about the oil pressure because my car doesn't have a gauge...only a dummy light. The car is a 69-912.
But that is a good thought. I'll install a dual press/ temp gauge and monitor the pressure.
Thanks!
Old 10-21-2017, 07:20 PM
Reiver
Reiver's Avatar
Thanks!
That is a horse of a different color and you might get a better response in the 912 section....
De Oppresso Liber
Old 10-21-2017, 07:45 PM
Russ
Good point...I was looking for advice from this section too because isn't exactly stock�� It uses some 911 cooling features but with a large displacement 914 block.
Thanks again!
Old 10-22-2017, 03:37 AM
