tmarx's Avatar
Help, Please! Stuck Transmission Oil Filler Plug
1985 Targa, 915 transmission.
So apparently the PO (or his mechanic) hadn't read 101 Projects when last changing the transmission oil and overtightened the filler plug - to the point of rounding it off to some degree. I've got the 17mm hex and it's fitting loosely and not getting enough "traction." It doesn't spin, but it doesn't stay in straight.
Worse yet, I made it a much bigger problem by (stupidly) draining transmission before removing the filler plug. So I've got a dry transmission and I can't get the filler plug out.
Any suggestions for tricks to getting that stuck plug out would be GREATLY appreciated!
Thanks,
Nate
Old 04-11-2010, 11:14 AM
tmarx's Avatar
BTW - I did search the forum and I'm reviewing those now, but thought I'd ask again as well.
Thanks.
Old 04-11-2010, 11:19 AM
Where are you in the Bay area?
I will come over with my welder, we can weld a nut, a bolt, a socket onto your filler plug and sacrifice it.
Get a new plug.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 04-11-2010, 11:21 AM
Warren Hall Student
Bobboloo's Avatar
I would put a 17mm impact wrench on it if possible or you could weld a fresh 17mm nut on top of it.
If no impact or welder is available then you could file the sides down enough to hammer a 5/8" socket on it.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 04-11-2010, 11:25 AM
Heat may help. Heating the case will cause it to expand more than the steel plug. Another option would be to put the fluid in through the vent on top of the tranny. Might have to do a "partial drop" to get access.
-Andy
Old 04-11-2010, 11:45 AM
usurpah's Avatar
You didn't mention if you've used any fluids on the plug. Try soaking the threads in Kroil for a day and then hit it with an impact wrench as Bobboloo mentioned. Order a new plug from Pelican today.
Eric C
'88 911
'14 Cayman S
Old 04-11-2010, 11:53 AM
tmarx's Avatar
Get a new plug.
Unfortunately, I'm not very close - Novato.
Old 04-11-2010, 11:54 AM
Senior Advisor
James Brown's Avatar
Try it with a pipe extention and pull real slow increasing your torque on it, then brake out the welder.
08 Cayenne Turbo
Old 04-11-2010, 11:55 AM
m110's Avatar
Welding on a nut would be my last resort but will surely work...it is a pain. Try heating the case, soak in Kroil the night before. You could also sacrifice a 12 point Allen style socket by pounding it in and cutting into the rounded lands with the 12 points of a slightly larger size.
1988 Carrera Coupe
Old 04-11-2010, 12:12 PM
tmarx's Avatar
Thanks for all the tips. One follow-up question -
Could I pump a full jug of oil (more than spec) through the drain plug and then replace the plug while it's gushing out? At least then I could get it somewhere with a lift rather than doing all this laying on my back with limited space.
Thanks again,
Nate
Old 04-11-2010, 12:22 PM
Senior Advisor
you could do that but just flip the car on it's roof, then you won't spill any.
08 Cayenne Turbo
Old 04-11-2010, 12:32 PM
ninelevenick's Avatar
I had this happen to me before. My filler plug was sticking out of the case about 3/16" or so. This was just enough meat for me to use a pair of vice grips. Using a piece of pipe for extension/leverage, I was able to loosen the plug.
Old 04-11-2010, 01:10 PM
one of gods prototypes
bell's Avatar
grind your 17mm hex so it's totally flat on the bottom, most of these have a slight rounding on the bottom, by making it flat you should get enough bite in the plug........heat too.....
Brought to you by Carl's Jr.
Old 04-11-2010, 02:36 PM
What the ?
glewis80SC's Avatar
Had this happen too, tried the heat with no success. Welding finally did the job. i do like the idea of grinding down the hex so its flat though.
SCWDP 73
1980 SC
Harley Davidson Road King
9/11/01 FDNY/343 Never Forget!
Old 04-11-2010, 03:02 PM
grateful user
don gilbert's Avatar
take a pointy punch, pound in an indention, then tap it counter clockwise out with the punch and hammer.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do.
Old 04-11-2010, 03:09 PM
Weekend Mechanic
vulcan300's Avatar
Definitely soak in Kroil or another penetrating lubricant first. Mae sure you scrub around the dran plug and spray with cleaner so that the penetrating oil can actually get into the threads.
Then put the 17 mm hex in the drain plug, use a large pair of vicegrips and tighten on the outside of the drainplug so that it is bent into contact with two flat edges of the hex. You can do this at two or even three positions and then just leave he vice grip in place for a little added grip. Then use your socket, a bar type socket wrench and a pipe extension if you need more torque.
This should get your fill plug out. If this doesn't work the welding thing is the next best bet.
86 911 Carrera Targa
Old 04-11-2010, 04:27 PM
Don't know if you have the room but if have any of the plug exposed a small pipe wrench would probably do the trick. I just serviced mine and I know the fill is in a tight location.
Old 04-11-2010, 04:33 PM
tmarx's Avatar
Thanks everyone! Victory was had through the following:
1) cleaning and then dousing with PB Blaster; soak for 1/2 hour;
2) using NAPA valve grinding compound to give the hex wrench more bite on the somewhat rounded edges; and
3) hanging a box wrench off of the end of the hex wrench and then using my jack to push up on the other end of the box wrench, thereby torquing the hex wrench.
Drives me nuts when a single-star difficulty job takes me five hours. Makes me hesitate to do anything that could be tricky! Anyway, new plug from Pelican is on the way. And, to tie this into a previous thread, I used Kendall NS MP. Hope to feel a difference - even a small one.
Old 04-11-2010, 06:31 PM
Northern Motorhead
wildcat077's Avatar
Nate,
There is another plug on the right hand aft upper end of the transmission that you could use to fill your tranny...
Should this ever happen to anybody else,jack the rear end of the car and remove the right side rear wheel and you will see the plug.It looks similar to the filler plug and if you drain the tranny completely all you have to do is put back in the proper amount through this hole.
It will keep your car in a driveable state until you can eventually remove the filler plug...
It worked for me !
Cheers!
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 04-11-2010, 06:45 PM
DUK DUK is offline
DUK's Avatar
Just wanting to make sure you are using the right Kendall oil. I don't think the NS MP is it.
This is...
Glocker Oil 33256 Kendall Axle Gear Lube
75 911 Indian Red- RUFWAN2B 2000 Boxster
2000 & 2007 Dobies
www.stahlwerks.com Cages and preparation for your Porsche
“People who never make mistakes must get tired of doing nothing”
Bill : The origin of the orgy of Porsche
Old 04-11-2010, 06:59 PM
