Heat with a 3.6l into a '76 Chassis
To make sure I'm not trying to reinvent the wheel here, how do you get good air flow through the SSIs without having ghastly pipes in the engine bay and totally ruining the look? Think you'll agree the look is worth preserving but my winters are too cold to ignore heat. Clearly I've left off the top piece of the fan shroud as I'm not sure which way to go and don't even suggest those terrible looking double rabbit ears Patrick are selling...
Formerly known as Syzygy
But to answer your question, I think Rothsport came up with some sort of hidden heat thing. I don't know much about it at all so best to check with Jeff or Scott. Regardless, fantastic looking engine. I hope it pulls just as good as it looks!
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. Last edited by Canada Kev; 11-03-2017 at 07:18 PM.. |
But let's try and keep this thread about how I'm getting my toes warm and my windscreen clear without ruining the look .
I like the clean and easy look of the carbon fibre pipe. Anything wrong using this?
Hi.
You could use the same setup as on the 3.2 Carreras. They have, in addition to the fan in the enginebay, two electric fans/blowers on the bottom of the A-pilars by the footwell. If you use the two in front you will get a pulling effect to assist the enginefan. Eskild Sent from my iPad using Tapatalk
Eng-o-neer
It's all trade offs. How clean do you want the engine bay? How much air do you need to move? How much weight and complexity are you willing to add? There are a few options.
What I would like to try is just using the flappers and footwell blowers alone, with no connection to the engine fan or rear blower. Just put a pair of air filters on the inlet of the heat exchangers. This removes all tubing from the engine bay, moves all blower weight right behind the front axles, and still provides plenty of heat and defrost capability. It might even allow a slight increase in engine cooling. Lovely, lovely motor. Last edited by Tremelune; 11-04-2017 at 03:34 AM.. |
Eng-o-neer
Down low you get slightly better throttle respose
Looks like I'm not the only one who thinks heater ductwork in the engine bay looks ****e! I posted a thread about this and in the first post I linked to a pic of the "hidden heat" setup on a 3.6, which you should look into. I believe it's Rothsport's creation and involves modifying the front tins on the side of the flywheel:
Re-Routing Heater Hose |
I found that the 3.6L engine fan did not produce enough pressure to use an RS type duct alone and the cross over tube to pressurize the right side was a pain to fit in an older chassis. It's a lot of fabricating between a 3.6L engine, earlier engine tin, RS heat tube, cross over heat tube, adapting all that to whatever heat boxes your headers have... I never got that set-up working very well. I had a 2.7L w/SSIs & backdated heat ducting that worked fantastically. I'd think for heat, SSIs would work great w/a 3.6L if you could get the air moving enough... and footwell blowers are an easy way to do that. Tom
'74 911 Red Sunroof Coupe, 3.6L, etc... '76 912 Yellow SPEC 911/911CUP |
I have of course crossover tubing to feed both heat exchangers, in my case around both catalytic converters. That plus the 2 footwell blowers works reasonably well for fall temperatures. Nothing for a real winter but who would care? |
I have an '80SC with a 964 3.6 transplant. I also have the carbon fiber
heat pipe, so no blower. i have found a trick to get more heat into the cockpit. All you need to do is slightly crack the sunroof (if you have one) about an inch or so, it doesn't allow any more cool air in, but the heat comes rolling out with about twice the volume. Try it you'll like it!
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa |
. But I like the concept of drawing air through the heat exchangers by creating a low pressure zone in the cabin.
If true, what suggestion do you have for headers with heat exchangers that will not rob the top end like that? |
And good look with your idea of catching forward air... |
What about one or two of those inline boat bilge blower motors? That's what we used to use as a booster in VW bugs. You might be able to hide them in the rear quarters or fenders and plumb them to the inlets of the SSIs.
78 911SC Targa, GP White |
