Guardsred911's Avatar
Air Injection Smog Pump Port Plug - How Difficult
I still have the piping system on the '77 2.7. Looking to see how difficult it is to remove and plug with the part offered on the host site. Guessing similar Degree of Difficulty with removing exhaust headers? Heat it up, use Kroil, etc...?
Any other Tips? thanks!
J
J
911 SC - 1980
911 S - 1977
Old 11-05-2017, 06:46 PM
Registered Minimalist
75 911s's Avatar
It's a bit of work. It can be done without removing the HEs. Kroil, yes, will probably help where the air pipe threads onto the air injectors. I think there is one that is nearly impossible to get to. I used a small crescent wrench to get in there and break it loose.
If I remember correctly, you must remove the muffler as the check valve is bolted up through the bottom of the rear engine tin. There isn't a lot of space in there either. Again, I used two small crescent wrenches to unbolt the check valve.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 11-05-2017, 06:57 PM
1/8" hex head brass pipe plugs fit nicely. Cheap too.
206 637 4071
Old 11-06-2017, 04:30 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
Did my 2.7, hardest part was jacking the car up, total non event.
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 11-06-2017, 08:55 AM
rip78sc's Avatar
Hi John - would the 1/8" hex head brass pipe plugs work on a 3.0 78 SC motor as well?
Looking to take mine off as well - pump has been out for years now.
Thanks Rob!
________________
78 911 SC Targa
11 Cayenne Base
15 Macan Turbo
Old 11-16-2019, 05:31 PM
Yup, same setup.
206 637 4071
Old 11-16-2019, 07:38 PM
