ducktail and hp increase
Hi gus
I read on several mags the ducktail was build to increase airflow to the engine as well and it gives a slight increase in HP did someone do a test before (no ducktail) after (ducktail) on a dyne and notice a real improvement, so more than 1 or 2 hp thanks |
You would need a wind tunnel to test this theory. A dyno is a stationary testing tool. 8/
I don't know about horsepower increase, but when my thermostat was unknowingly stuck closed I saw lower oil temps with the duck as opposed to without (no front cooler, just engine mounted).
-Jayson 1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85) IG: Signature_911 |
Speed Metal Army General
The cool factor alone raised my HP instantly!
Reiver
Mine is even faster in reverse with the duck!
De Oppresso Liber Strength and Honor 5th Legion |
Whales are more efficient in this regard too.
Under the radar
I thought spoilers spoiled the laminar flow.....
My ducktail raised my 86 Targas RWHP to 211! I'm sure it has nothing to do with my Steve Wong chip and M&K muffler!
So i will do the test in a few weeks
Location: behind the redwood curtain, (humboldt county) california
The Porsche Story
The duck also moved the aerodynamic center of pressure rearward,, thus reducing side wind induced instability. He also mentioned that the duck also slightly, (1-2%), reduced the aerodynamic drag. I have seen a couple of threads mention a noticeable reduction in oil temps going back and forth between stock engine lids and ducks, although, I am at a bit of a loss to explain why, given that the oil flow to the coolers is controlled by 1 or 2 thermostats. We are left with the assumption that the duck increases the flow of air into the engine compartment to benefit both cooling and Hp. My 74 is down for a front end refresh and a duck instalation, but, I am thinking about doing a before and after engine compartment air pressure test, at roughly 100mph, just a quick test, si I don't get busted. Chris |
That will be an interesting test! |
ducktail
It increases the HP thru the corners with downforce
![]() Mike
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago. |
The ducktail does not add much downforce. It reduces the amount of lift or negative air pressure in the rear of the car. While driving without a ducktail, air is drawn out of the engine compartment by the lift thats created (like the wing of an aircraft). The engine fan and intake are fighting with the negative air pressure. With the Duck, there is neutral or just a bit of positive air pressure. This will definitely give a bit of extra cooling CFM's and intake CFM's to the engine. Plus it just looks real cool.
Chris |
The tuner i m doing the dyno have a huge fan to simulate high speed
So for sure it s different from real world But it will give a good indication |
GOM (Grumpy Old Man)
duck tail = 1-2 hp
Pegasus decals = 5 hp Luckily I have both!
Instagram: @3pedalposse |
only in combination with front lip! 1970 911 RS clone Aerodynamics question honestly, it DOES help! without lip 'n tale running upt to 220 on the straight was sweatty. now I run full limot with my SC 240 and feel way safer.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit Last edited by Flojo; 11-09-2017 at 07:11 AM.. |
