Help with Backdate of Front Latch Panel
Hi Pelicans,
I'm in the process of removing the front latch panel. This is on a 1972 that was front dated with a front clip of a 74-89. I have drilled out I believe all of the spot welds and some welds of the edges of the seams had to be cut out. I'm trying to wrap my head around how to get it out of there as it seems to be locked in as it wraps around the pan back and forth at the bottom. I purchased a spot weld chisel to assist in breaking the welds, which has worked. If you have completed this and can advise please chime in. This first pic shows the inside where the panels wrap around each other making so you can't simply pull the panel out... Thanks for your help, Rodney
Rodney Nelson - '72 911T (Undergoing Full Resto), '82 SC (Grand Prix White) Gone for 20 yrs and now back, '86 951 (Guards Red) Caught Fire, '71 911T (Tangerine) Sold, '72 911E (Grand Prix White) Sold, '86 951 (Black) Sold, '79 SC (Grand Prix White) Sold, '71 911T (Irish Green) Sold |
Any ideas? Or help? Thanks...
Are you trying to save the 74/89 latch panel? If not, cut it into pieces and out it comes surely?
1972 911T Coupe with a '73E MFI engine and 'S' pistons 10 year resto mostly completed, in original Albert Blue. ***If only I didn't know now what I didn't know then*** |
I just did this. As mentioned. Cut around the edge . Once large center section is out. You can work your way around removing the edge.
I would rather be driving
Cutting out is the only way. You will not clear the inner fender panel lip or the lower pan overlap section.
Also, the lower weld seam will have a weld bead right where it ends on the inner fender and meets the front pan. You will have to cut this with a wheel or saw.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Thank you everyone for your advice. Some time the obvious is not obvious! Like cutting it out. Heck no I don't want that front latch panel, I'm mad at it and the PO that put it in, I will be more than happy to cut it out. I will get update my progress later on after this weekend.
Subscribed as I have the same project to do on my 1972 that was converted to short-hood in the 1980’s... why did they do it?!?!?
Ächtung Kraft Founder - Custom Porsche Parts and Leather http://achtungkraft.com - Bryan Rasch - bryan@achtungkraft.com INSTAGRAM // @AchtungKraft // @BrightonRennsport 1972 911 ROW Steel Wide body Outlaw w/'86 turbo drivetrain 1976 911S + 2006 911 4S + 2009 Cayenne GTS + 1988 944 |
Good news is I got it out and I took some pictures. So, the first this is yes, you need to cut it apart, the obvious that I overlooked. Here are my steps... 1. Drill out all of the spot welds from the front of the panel and I did drill some on the inside where the latch panel meets the pan on the inside corners. 2. Use a Spot Weld chisel to break free areas. Which I did a lot where the spot weld was not completely removed by the drilling. 3. Cut the latch panel major section all around where the it does not touch the side panels or pan with a sawzall. 4. Cut the lower center of the remaining panel in half once separated by the chisel and loosened from the pan with a dremel tool or something similar so you don't cut the pan behind. 5. Now work the sides out of the latch panel where they meet the corners of the wheel well panels. Start loosening from the top, drilling out areas that you missed and hammering free with the chisel. 6. Good Luck!
Some more pics...
All Done...
Under the radar
Next up, the bumper mounts?
Are you going to replace the battery boxes? Looks like a great project, keep posting your progress.
I posted a poll a week or so ago regarding the battery boxes. 2 to 1 said to leave them off...
Cars and Cappuccino
I used my bumper shock mounts for the rotisserie I used. Cut and welded some bolts to the end of the factory shocks and used some beefy nuts to hold it all in place when on the rotisserie.
http://www.carsandcappuccino.com 1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits 1985 Prussian Blau M491 Targa 1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe 1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday) |
911 Mania
Nice work, enjoy following your progress.
"When the debate is lost, slander becomes the tool of the losers." Socrates |
I totally agree. I cannot believe that people are backdating SCs and Carreras. I have owned a couple of SCs and they are great cars, that should not be backdated. I'm for customizing but with minimal serious changes to the vehicle. Otherwise in the future these people will be referred to negatively as the "PO".
Under the radar
I cringe every time I see a ....."backdate...." thread.
