980 980 is offline
Hack with a plaque
Question SC PMOs - Heater options?
Been lurking here a long time. Thanks for all the info all these years.
I'm installing a set of PMOs on a SC that I'm rebuilding. Obviously there's no longer a home for the blower. I've seen photos that seem to use the early style tins on both sides of the fan, but I'm not sure what fan housing they're using.
Can I source early style "hot air sockets" and install them on the existing (1980) fan housing?
I believe the PMO instructions reference JB racing for tins, but they're web site is a bit vague.
What solutions has the community come up with?
Thank you.
Old 11-15-2017, 08:30 AM
ROW '78 911 Targa
timmy2's Avatar
Pelican Parts Technical BBS - Search Results
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 11-15-2017, 08:34 AM
980 980 is offline
Hack with a plaque
Originally Posted by timmy2 View Post
Thank you! I did a good amount of searching for "PMO", "heat", and "heater" with little results. Apparently "backdate" is the key word I was missing. Now I feel like and idiot.
Thank you!
Old 11-15-2017, 08:42 AM
Hi.
Yes you can use the old style heat components.
If you zoom in on the pic you will see how
Old 11-15-2017, 09:04 AM
Fleabit peanut monkey
Bob Kontak's Avatar
That is what questions are for.
Only a handful are experts here and they probably cut their teeth when Reagan was President.
1981 911SC Targa
Old 11-15-2017, 11:46 AM
Actually, when Lyndon Johnson was President.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 11-15-2017, 05:49 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Thank you!
Don't, took me a while to figure out the Advance Search:
i.e. if you type PMO and Heat and choose Search Entire Post you get: Pelican Parts Technical BBS - Search Results
Guess who's post is on top???
Who Will Live... Will See
Old 11-15-2017, 06:15 PM
ROW '78 911 Targa
timmy2's Avatar
No worries, figured I’d give you a bunch to read as I was at work and didn’t have time to type an answer.
Dennis
Old 11-15-2017, 07:59 PM
Fan
Originally Posted by Litle brother View Post
Hi.
Is that a fiberglass fan?
Old 11-16-2017, 07:29 AM
No it's the original. It's just painted with clearcoat that has marmorized.
Old 11-16-2017, 02:40 PM
980 980 is offline
Hack with a plaque
Thanks for all the replies.
Litle brother, that's a beautiful engine you have there. I've seen it many times while researching this build.
I'm noticing all most of the backdating threads I see are builds that don't have A/C. This car has a/c still, just not working now or in the near future. It looks like the bank 2 engine tin clears the a/c bracket, but the ducting doesn't? This post seems to support that.
Also I like this DIY setup here. I like how it uses the exsisting duct. I'm not a fabricator though.
The engine is still on the stand. Trying to get as much of the Carb set up done before I put the engine back in. Also I'm not entirely sure the A/C compressor and condenser will clear the PMO's and filter assemblies. We'll see.
Thanks again.
Old 11-17-2017, 11:55 AM
Thanks again.
Thank you very much 980
Good luck with your project
Old 12-09-2017, 01:00 PM
3rd_gear_Ted's Avatar
That is an awesome PMO set up.
Gotta ask; Engine mounted Coil assembly vibration isolation, how and what?
1980 911 - Metzger 3.6L
2016 Cayman S
Old 12-09-2017, 02:32 PM
JJ 911SC's Avatar
Originally Posted by 3rd_gear_Ted View Post
... Gotta ask; Engine mounted Coil assembly vibration isolation, how and what?
None. These DFU's are fully "poted". Had mine mounted directly on the engine quite a few years back with no problem.
"In electronics, potting is a process of filling a complete electronic assembly with a solid or gelatinous compound for resistance to shock and vibration, and for exclusion of moisture and corrosive agents. Thermosetting plastics or silicone rubber gels are often used."
Old 12-09-2017, 03:59 PM
