Drivers side window rattling
The drivers side window on my 84 Carrera rattles when it's anywhere in the middle of its travel. Passenger side is fine. Anyone have any ideas what the culprit might be?
Old 10-24-2017, 08:53 PM
Flojo's Avatar
something came loose for sure.
I guess you cannot avoid removing the door panel and lurk inside the door with a torch.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 10-25-2017, 01:14 AM
wayne robson's Avatar
window
Just remove your door panel, you will see on left side about half way down
the adjustment bolt to move your window guide towards the front,usually
all you need is about 1/16.
What happens the front felt guide wears out and becomes sloppy
so this fixes the problem.
hope you understand my explaining.
Old 10-25-2017, 03:20 AM
Cevan's Avatar
I have the same issue and assumed the guide felt is worn out.
Wayne, are you referring to the height adjustment bolt in the lower photo below?
1986 Carrera coupe - black on black
1972 CB500/4
Old 10-25-2017, 05:04 AM
window
No sorry ,looks like the bottom photo.
i have a targa, i think should be similiar, i did mine couple of years ago
and fixed mine.
but i remember just moving mine a little towards the front.
regards .
Old 10-25-2017, 05:46 AM
Wildman Emeritus
Subbed.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 10-25-2017, 06:27 AM
theiceman's Avatar
id think carefully before making window adjustments, especially with a targa as the window adjustments are very precise to make the correct seal with the roof and all weather stripping involved. If you can see if something is worn replace it, as making adjustments to compensate for it could be a long noisy road ahead in a Targa.
mine ratles too when I close the door with the window down , I chose to live with it for now because I lived the tale I tell. Relieved I got it back to original position in the end.
1976 Yamaha XS360 ( Beats Walkin')
1978 911 SC Targa ( Yamaha Support Vehicle )
2006 Audi A4 2.0T (Porsche Support Vehicle )
2014 Audi A4 2.0T Technik (Audi Support Vehicle)
Old 10-25-2017, 07:32 AM
Does the actual window rattle, or is there a faint metallic/plastic rattling sound from within the door?
When I last took my windows out, I removed all of the nasty grease in the horizontal track where the plastic wheels run at the bottom of the window glass. Turns out, they are a very loose fit, and that grease helps prevent them from rattle around a bit in the track when the window is not 100% up or down.
So, my window glass doesn't move, but there is the faint sound of the plastic wheels moving around in the track, which sounds just like a rattle.
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 10-25-2017, 08:22 AM
Those pics will help. It definitely sounds like the window but I suppose it could be something else. I'm going to have to remove the panel and figure it out. Thanks for all the information!
Old 10-25-2017, 08:41 AM
Driver
Noah930's Avatar
My WAG is a broken window regulator pivot. I had a rattling noise from my partially-opened passenger side door because of that. It would still go up and down, but had a rattle anytime it wasn't full-up or full-down.
If that's what it turns out to be, here's what I did to fix it: Window regulator pivot replacement
1990 Black 964 C2 Targa
Old 10-25-2017, 09:42 AM
DWeg1998's Avatar
911 electric window rattle -- the fix!
Try this thread. It worked for me. The vertical adjustment of the Allen bolt for the inner rail did not fix my problem of a rattling window when open half way. What did work for me was the suggestion to add washers on the inside of the bolt to change the angle of regulators horizontal rail that is attached to the door and put a little tension on it.
http://forums.pelicanparts.com/uploads2/Adjustment1084922819.jpg
Old 11-05-2017, 03:40 PM
UPDATE: I greased (heavily) the horizontal track and wheels as well as made an adjustment to the allen bolts (lowered a couple mm's) and everything quieted down. I was out over some various quality roads for several hours yesterday and not a peep! Was amazing how much noise that window was generating.
Old 11-18-2017, 07:18 PM
DWeg1998's Avatar
Good to hear, nice job!
Old 11-19-2017, 05:38 AM
Josh D's Avatar
Better hope you never have to go back in and remove the window regulator! I solved the rattle issue with grease as you did. Several years later, window movement froze. It was due to a couple of the teeth of the nylon spur gear in the window motor assembly breaking and causing it to jam. Anyway, everything had to come out and it was a freaking mess dealing with all that grease! Wish I had never done that.
The window bottom channel are known to rust and weaken, allowing them to rock back and forth from the up and down forces. I think this contributes to the rattle. Mine was shot and had to be replaced. It works great and is quiet now with just a minimal application of white lithium grease for lube, not to quiet rattle.
'80 RoW 911 SC non-sunroof coupe in Guards Red
It's not a Carrera.... It's a Super Carrera!
Old 11-19-2017, 06:20 AM
