Pete/Tony: just go back from garage, after completing 12 V test at FP terminals. I didn't get 12 Volts, but not 0 Volts either. Two readings: 8.7 V and 9.5 V. And resistance across the FP terminals at 0 ~ 1.5 Ohms.
During testing, the pump did not turn on, did not run; no sound, no vibrations. After the test, the FP was warm to the touch; definitely a noticeable difference warmer than other parts down there. - FP relay removed - jumper wire w probes in pins #30 and # 87a - jumper wire toggle switch "ON" - key at "ON" position First Test w Multimeter MM: MM + probe to FP + terminal MM - probe to FP - terminal MM reading: 8.7 V Second test w Multimeter MM: MM + probe to FP + terminal MM - probe to cross member bar as a grounding point MM reading: 9.5 V Third Test, Ohms w MM: MM + / - probes to FP + /- terminals MM reading: 0 ohms ; sometimes 1.5 ohms depending on where I contact the probes .
1983 911 SC Coupe w Sunroof, Metallic Silver --- AKA 83 Silberpfeil |
Jonathan, When you did the above tests, did you test or confirm if you were getting voltage @ terminal #30 and at the positive (+) terminal of FP? Have you applied 12-volt directly to the positive (+) terminal of the FP? Use a 12-volt automotive test light for this type of work. The hardest part of this job is removing the skid plate under the car. Once you got the FP exposed, testing will only take a couple of mins. to determine if the fuel pump is good or bad. If the tests show that the FP is bad, remove it and do a second test on the bench. If it fails again, whack it with rubber mallet or drop it to the floor a couple times and see if it runs or not. I have a box of defective fuel pumps and sometimes I could find a running FP by shocking it or dropping it to the floor. And use it for my CIS bench tester. Not recommended for car use. I just realized that you have hijacked someone’s thread. You should had started your own thread. Tony Last edited by boyt911sc; 04-04-2023 at 07:46 PM.. |
You're right Tony --- I did hijack LIRS6's thread. I'll send him a PM.
Let me start a new thread to continue discussions here...1983 SC - Reviving after ~ 4 years dormant
Thread Tools | |
Rate This Thread | |
