mikl911
CIS to Carbs questions
Just finished the CIS to carbs conversion but i'm not sure if I need the vacuum line from the distributor or not. I have not had the distributor recurved yet, will it hurt to run it, as is, a couple of times just to check for leaks etc?
Mikl911 1967 911 RS clone owned since 1992 1978 911 SC/R Sinister hot rod 1937 Ford Slant back Hot Rod 2000 M5 ECU upgraded (sold) |
Location: behind the redwood curtain, (humboldt county) california
No problem
The vacuum advance is a load compensating device. At part throttle,or light load, the charge density is less than full throttle and by using the vacuum to advance the spark, the engine becomes more fuel efficient.
This will cause no harm to the engine, only a drop in fuel efficiency. Good luck, that is a nice looking install. Chris |
mikl911
Thank you Chris.
mikl911
In case anyone was wondering I was able to get the CIS out without removing the motor, just dropped it down about 4 inches.
Let us know how you like the swap, performance wise and mileage wise, when it is driven for a period of time. I have a RS spec 2.7 and get crappy mileage but my foot is into the floor a lot.
mikl911
zedsn, I will. CIS was working great and the 3.0 only had about 1000 miles since rebuild with 9.8, 964 cams and SSI good or bad I should see a difference. My 67 has a 2.7 with the same set up so I'm used to the poor mileage.
I think any major change is optimized with a pro synonym tune.
Theory, done a ton of changes to a lot of cars & trucks,, but have been reading the threads and seeing significant HP and Torque improvement, optimizing, on the dyno. I have changed to webbers, fussed with jetting, but I know I have missed out on a lot of hp, tq, and throttle response.
Get help balancing the carbs, jetting, or the EFI, setting the timing, Christ, I need help choosing a 2 in 2 out for my dead stock, CIS 2.7, I am planning on budgeting real bucks, getting pro help to get it RIGHT. Got Chris 7's light flywheel, and am planning on a light clutch. God loves a snappy 6 Best, Chris |
Banned but not out, yet..
Spoiler alert. I have ‘82 3.0s in both my cars and the SC with CIS gets low 20s on long haul freeway driving. The 914 with Webber’s gets mid teens doing the same. Hammering the 914 probably gets me down to the high single digits. A good friend of mine calls carbs a ‘controlled fuel leak’. Do like the added torque though, but the gas smell in the garage from evaporation from the float bowls is a bit much. Now back to the thread already in progress.
An air cooled refrigerator. ‘Mein Teil’ Last edited by RSBob; 11-19-2017 at 10:04 PM.. |
mikl911
chrismorse, you will not regret the lighter clutch and fly wheel the throttle response is very noticeable. Besides gas mileage the only down side to the carbs, I have read, but not notices in my 67, is in top end. I don't know about the rest of you but NY state troopers really frown on you cruising at 110-140. Almost all of my driving is spirited 0-75. When I want the fastest car on the block I'll buy a GT3 or a Mclaren for now I'll enjoy the 1. better torque 2. better look, by far 3. better sound and 4. better reliability the Webers offer. And for those that will ask why not EFI simple, cost, not the cost of a system I had one brand new still in the box and just sold it. The cost of the learning curve mentally and finically, with dyne time ( I'm a little obsessive and would have wanted it to be perfect). I understand carbs and have friends that understand them because we are old lol. My 2 cents.
Wondering how the drastic weather changes here in upstate NY would affect carbs??
mikl911
Dpmulvan no issues. I have heard that altitude effects them more, not an issue in Rochester.
I have a carbed 2.7 and can whole-heartedly agree on both:
1. proper tuning and syncing will help fuel economy tremendously 2. any improvement in fuel economy becomes immediately negated by proper application of the right foot
youtube.com/bennyobscene |
AirBorne!
I have obscene carbs in a 3.0 . I don't worry about mileage. Foot to floor. Fill up the car every three days.
2008 997 C4S Silver, Kitty Cat, 1989 3.4 911 Silver Carrera, Erica, 1989 944S2 NASA GTS2, Iris, 1988 944 DE Car, Backdate 1975S to 1970s w 3.0 PMO - Roxanne, 1967 911 normal w 2.2s engine w S goodies, 89 VW Cabriolet - 2.0 conversion - sold and missed |
Thats what its all about....Fuel Mileage? Really guys? Smiles not miles!!!
1980 911SC #99 track car, 993 3.6, 50 PMO's 2019 Ford F150 da dragger 2015 MB SL400 wifey DD 2008 E93 M3 DD 2007 E60 530 wifey winter beater |
Vaccinated and Boosted
Enjoy!
2013 911 Turbo S 2025 Lexus TX350, 2024 Honda CRV Hybrid 1930 Cadillac V8, 1991 Ford F250, 2023 Chevy Colorado And some garage space.... |
mikl911
mgatepi I also have the big port heads, did you have the distributor recurved? I had a similar issue with the 2.7 with Zenith carbs it would not idle, hesitated below 3000 rpm but came on strong after that. Switched to webers, same problem until one day I decided to run non-ethanol gas, fixed the issue immediately has been running strong foe 4 years no issues.
I actually purchased a new distributor from Clewett Engineering.
After the 3000 rpm lag...hold on! It comes on strong. Interesting about the gas. I will give it a try. Thanks!
Also, the Clewett distributor does not have a vacuum advance.
