MAF back to AFM
Has anyone gone back; from MAF to AFM?
I have an Autothority MAF/Chip with giant K&N filter (put on the car 19 years ago). The car runs rich and idles high and I think this may be part of the problem. Also Steve W suggested I switch back when I contacted him about a new chip about a year ago... (maybe because it would be more expensive to program for the Autothority MAF? I forget)
What do I need to put it back together? How is it done? And don't say read a MAF thread then do it backwards
Old 11-17-2017, 07:27 AM
Just replace the MAF with the AFM, then open up the DME and replace the
Autothority chip with the original stock chip. Simple as that!
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 11-17-2017, 07:48 AM
try the hot wire. it may be dirty. My maf is 26 years old. Only maintenance was replacing the potentiometer about 15 years ago due to its shutting down the system. I would not replace the MAF.
1987 Guards Red Targa, cams, exhaust, MFI intake, lowered, 7 and 8's, 200,000 plus miles of smiles
Old 11-17-2017, 05:18 PM
faverymi's Avatar
I had a MAF in my carrera
I replaced sensor. Its a Ford part number
Later I got everything back to stock buying parts from the forum
Many moons ago
Old 11-17-2017, 06:11 PM
jungspike's Avatar
I swapped back. Too difficult to get the AFRs correct. The only thing I lost was some engine sound coming from the intake. Yes,all you need to do is swap the chip and MAF. Also you will have one extra 12v wire that powers the MAF to cap off.
If you got more questions contact Sal Carceller (scarceller screen name) on here.
I got the MAF sitting on a shelf. Anyone know what it is worth?
84 911 Targa 3.4L
Old 11-17-2017, 06:46 PM
Thanks for the comments, sounds easier to do that I thought.
Do most people recommend sticking with the AFM/switching back?
Old 11-20-2017, 07:26 AM
kuehl's Avatar
If you have Sal's MAF system, you'd probably not switch back to the old AFM .
Sal's MAF
Kuehl
1987 911 cab, modified
https://griffiths.com/
Old 11-20-2017, 03:16 PM
I had an autothority MAF on my 944 turbo years ago and switched back to my AFM and put in a different performance chip and all is well. I have been told the the stock AFM is designed to take up to 350hp.
Old 11-20-2017, 03:21 PM
I'd first try cleaning your AFM as referenced above and seeing if you can get your 3.2 running properly as-is.
My '86 targa has an afm/chip combo that my wrench developed. Around 30k miles after install, it too developed a rich condition, which my wrench resolved by cleaning the sensor.
It's otherwise provided me with a nice improvement butt-dyno-wise since install.
Old 11-20-2017, 03:57 PM
Grappler
Rodsrsr's Avatar
Sal's MAF
This.... a true upgrade in performance, drivability, mileage.
Grappler
Know Gi / No Gi
1976 RSR Backdate (Turbo 3.2)
Old 11-20-2017, 04:03 PM
