Author of "101 Projects"
Wayne 962's Avatar
Today's Trivia Question!
Was asked this question today, and I did not know the answer.
Which direction does the distributor turn in a 1976 Euro Carrera. A fellow bought one that was burned and didn't have the distributor and wanted to know which one he needed. My tech editor for the book didn't know either.
All three engines that year (2.7 / 3.0 Turbo / 3.0 Carrera) used the same crankshaft. I saw a 3.0L engine that had points, like the 2.7 (clockwise), whereas the 3.0 Turbo used electronic triggering. However, the 3.0 Carrera engine was the precursor to the 911SC, which had the distributor turn counter-clockwise.
If I were to guess, I would guess counter-clockwise, but as I said before, not sure...
-Wayne
Old 05-13-2004, 02:04 PM
echrisconnor's Avatar
I'm not looking at my car right now, but from memory, I could swear it turns clockwise. I'm about 85% sure...
'76 911 Carrera 3.0
Old 05-13-2004, 02:08 PM
Eric Coffey's Avatar
Not sure either, but since it's a Euro Carrera, it should be the same spec/direction as the MFI 2.7L RS.
Old 05-13-2004, 02:24 PM
Wayne 962's Avatar
The question is about a 1976 Euro Carrera. You're thinking of the 1974/75 European Carrera which indeed was the same engine as the '73 RS. In 1976/77 they went to a very unique aluminum block based on the big brother 930 engine of 1976-77.
-Wayne
Old 05-13-2004, 02:27 PM
Bill Verburg's Avatar
That's easy, all the point type distributors 2.0, 2.2,2.4,2.7 and 3.0 turn the same direction, clockwise. The counterclockwise rotation was used from '78 on the SC and then back to clocwise again for the 964.
Bill Verburg
Old 05-13-2004, 02:29 PM
Non Compos Mentis
North or South Hemisphere?
Old 05-13-2004, 04:05 PM
The part number on my 76 euro distributor is 0 231 184 007 and I probably spend way too much time watching it turn clockwise.
Will R.
87 Carrera 3.3 Turbo
Old 05-13-2004, 05:16 PM
SC-targa's Avatar
"That's easy"!! Bill, I'm beginning to worry about you.
Jerry Kroeger
82 911SC Targa
(05 Boxster S ) gone, but not forgotten
87 Suzuki GSXR-1100
1953 MG TD Mk II
Old 05-14-2004, 06:43 AM
thanks you all this info just helped me out thanks again slammin
Old 12-04-2017, 06:11 PM
I need to amend my answer above
the distributors went back to clockwise rotation for the 3.2 Carrera in 1984
The only counterclockwise distributors were those used in the '78 - 83 SC
Bill Verburg
Old 12-05-2017, 05:35 AM
