Speedometer and wipers didn't work
Hi,
Last week I drove with my 911 SC (1980) and the speedometer and windshieldwipers weren't working.
After I parked the car and started after half an hour the speedo and wipers came to life again...
I checked the wiring diagram and couldn't find a common spot, except the ignition switch (pet-number: 91161301701).
Could the ignition switch be the culprit? That due to aging it sometimes fails?
And for replacing I see 2 approaches:
- removing the entire assambly by drilling the break-away bolts: Pelican tech article
- Only replacing the switch-part by diving behind the dashboard: Youtube-video
Which do you recommend?
So in fact 2 questions:
- Is the ignition switch the root cause of the problem
- How to replace it as easy as possible?
Thanks for your replies!
For the best wipersblades in The Netherlands and Belgium: www.nieuweruitenwissers.nl
Old 11-25-2017, 02:43 AM
Just went thur the same problem. You have a burnt out wire some were which requires an electrical tech. Took about 3 to 4 hours to fix https://notresponding.net/windows-media-player-not-working/
Old 11-25-2017, 02:53 AM
Does somebody else knows what's the issue is?
I can't imagine that it's a burned wire because then it would never work, isn't?
Old 11-30-2017, 02:15 PM
