Send a message via AIM to sempaipaul
Painting Metal Engine Shroud parts.. what paint to use?
Guys,
I am cleaning up the engine bay and trying to paint all the metal side covers/shrouds. What do you guys recommend for paint? I completely stripped all the parts - and tried the rust oleum ceramic engine enamel - and it didn't seem to stick so well.
Any ideas?
Also I need to paint my oil tank.
Thanks,
Paul
03' Audi RS6; 16' 328i xDrive Touring; 13' X3 mSport, 91' e30 M52
Old 02-28-2014, 07:42 PM
Cooper911SC's Avatar
If they are really stripped to bare metal, make sure they are wiped down with a prep. solvent or lacquer thinner.
Next apply a light coat of self etching primer. I like SEM, UPOL, or Wurth brands. This will grab ahold of the metal.
Next use any of the "favorite" satin or semi flat blacks.
Wurth Satin, SEM Trim Black, Rustoleum 7777 satin, Krylon satin black etc.
I did mine years ago with Krylon and it is still looking decent.
Cooper
Old 02-28-2014, 08:59 PM
al lkosmal's Avatar
Get them powder coated.
RGruppe #669
http://www.x-faktory.com/
Old 02-28-2014, 10:11 PM
What he said, got mine done a couple weeks ago and they came out amazing. I just wish I had taken before pics. I got 7 pieces done for $200. I paid an extra $50 for zinc primer... Not sure if that was necessary or not, so could have gotten it done for $150.
I could not have ever painted them to level they are finished at now.
1982 911 Targa, 3.0L ROW with Webers
Old 02-28-2014, 10:16 PM
Old 02-28-2014, 10:18 PM
The 9 Store
powder coat is a no brainer. I just got 12 parts done in satin black for $75 and that included the glass bead blasting. Just look online and see if someone does it commercial in a nearby industrial park, There are a couple people on pelican who do a nice job but if you have a bunch of parts, it is more cost effective to drop off local.
Old 03-01-2014, 05:32 AM
Powder coat is the way to go. If you must do it yourself rustoleum 7777. Available at walmart.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 03-01-2014, 06:41 AM
Whatever you use, it's best if the paint is compatible with solvent, oil and/or gasoline, all of which are in close proximity.
Sherwood
Old 03-01-2014, 07:29 PM
ROW '78 911 Targa
timmy2's Avatar
I blasted mine, cleaned them properly and used a good primer as suggested earlier, then black semi gloss engine enamel. Worked well.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 03-01-2014, 10:48 PM
Weseeeee911
I went with powder coating them. It's a nice durable finish!
Al
80SC 95-present
Old 03-02-2014, 07:58 AM
Powder coating would be good.
I would paint with Rustoleum satin back 7777. Home Depot, Wal Mart etc. very very good stuff. I have some applications that have been there for 6 years and still looking great.
I love this stuff.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 03-02-2014, 08:47 AM
Still here
pmax's Avatar
So, what's the verdict between powder coating and rustoleum or equivalent rattle can spraying ?
Sending the parts back and forth for powder coating sounds like it's too much hassle for these parts on a non showcase engine.
Old 11-09-2017, 03:59 PM
Shaun @ Tru6's Avatar
Everyone needs to stop powder coating everything. It's typically thick and ugly making everything look like a 2001 Ford Taurus and a bi tch to get off when you want to do it right. Hard candy shells should be left to M&Ms. While not important for sheet metal, it also hides cracks on things like wheels.
Nothing wrong with sanding/media blasting and then using professional quality primers and paint. You can go down to your local body shop supplier and they'll mix you up a can of proper paint you can spray. $25 a can but it's done and done right.
Cerakote is a much better alternative to powder coat if you want to go that route.
Tru6 Restoration & Design
Old 11-09-2017, 04:12 PM
All good advice, but also need to use the material(s) appropriate to the application. Solvents used in the automotive world (gasoline, lube oil, brake fluid, etc.) are not compatible with all paint coatings. It would make sense to use the best product to protect the base material without introducing negative consequences.
Sherwood
Old 11-09-2017, 04:29 PM
I agree Sherwood and one reason I would go to the experts at a paint supplier to get the right paint. Cerakote is impervious to everything, even aircraft stripper, but will media blast off easily being so thin.
Old 11-09-2017, 04:33 PM
Under the radar
Trackrash's Avatar
I have used semi gloss ENGINE enamel and it has held up well and looks good. I used Prep N Prime to treat the metal after I cleaned it up.
Gordon
'71 911 Coupe 3,0L outlawed
Old 11-09-2017, 04:35 PM
Right on, and Thank you for saying so. Have used various automotive enamels over the years, with hardener, and eggshell to very good effect. Have used rattle can Rustoleum and Duplicolor too with decent results. Powdercoat never looks right to my eyes.
Old 11-09-2017, 04:39 PM
Been almost 4 years since I got my tins powder coated and they still look like the picture I posted above. Save for a little residue from topping off the oil and regular old dust. They wipe down very nicely too.
Old 11-09-2017, 04:50 PM
3Ddesigns911's Avatar
+1 for powdercoating
Old 11-09-2017, 08:08 PM
VHT brake caliper paint, satin black, two coats then bake it on at about 300 deg F. It's resistant to heat up to 600 and oil or brake fluid don't effect it.
Old 11-09-2017, 08:39 PM
