smarens's Avatar
should this have caused an Alternator issue?
see picture below, I believe this is the ground wire, you can see the case bolt to the right of the eyelet the nyloc nut is loose
-car was charging normally, never saw any indication of any issue
-doing some work so I will reconnect when done, that is the main ground wire
correct?
1975 914 1.8l
1979 911SC Targa - In Restoration
1972 Pantera
Dune Buggy Dual Port 1835cc
1980 911SC Targa - Driver/Winter Project
Old 12-16-2018, 05:24 PM
Yes, and it is brown. I am not surprised everything was working fine because it is actuall an extra
Precaution to have that wire, but it does give a solid ground. The case of the alternator is grounded to the car by default right?
Old 12-16-2018, 06:29 PM
smarens's Avatar
I was assuming the same, waiting for an expert better than me to confirm
1975 914 1.8l
1972 Pantera
Old 12-16-2018, 07:57 PM
Jameel's Avatar
When I rebuilt my alternator a few years ago my ground wire was not connected, just like yours. Drove the car for thousands of miles this way with no issues. My alternator was rebuilt "while I was in there" because I was making the fan and housing pretty
1983 SC Coupe Chiffon White
3.0 rebuilt by me
9.5:1 964 Cams. SSI's. Backdated heat. KEP sports clutch.
Old 12-16-2018, 08:19 PM
That is one dirty engine. Yuck.
Old 12-17-2018, 09:22 AM
Jonny H's Avatar
Definitely connect the ground strap.
The early cars did rely on the contact between fan housing and case to ground the alternator. This would not pass any electrical design review these days. For example, metal electrical cabinet doors have earth straps.
www.classicretrofit.com
Old 12-17-2018, 09:41 AM
smarens's Avatar
hey that was not the purpose of this post
-JK, yes very messy, usual suspects, triangle of death, rear main, valve covers, will be cleaning all and fixing all leaks, my other post will show the pretty pictures when done!
1975 914 1.8l
1972 Pantera
Old 12-17-2018, 10:18 AM
Yea, sorry. My engine had lots of leaks, and never got quite that dirty. The triangle of death and oil cooler seals helped a lot.
Good luck with your project.
Old 12-17-2018, 01:50 PM
smarens's Avatar
thanks Glen, zero offense, took it as the fact it is!.... but not for long I want and engine to be proud of
1975 914 1.8l
1972 Pantera
Old 12-17-2018, 02:14 PM
